E34 vs E35
Bardo
I have been shopping E35 MK II or MK III's (See my boat wanted post), but I have found a couple of E34's that are very reasonable and kitted out for cruising. In looking over the specs, I see that the 34 is actually longer at the water line (26-6) and wider in the beam (10-11) than the 35. Other than the 1 ft in length difference, can someone clue me in to the design or performance differences between these two boats? I have not found a cabin layout for the 34, but the pix on YW look as if it is the same as the 35. Any help here is appreciated.
Freeman
treilley
The E34(T) falls somewhere between the 35MKII and MKIII in performance. I am not sure about the X. Both have a traditional layout while the 34-2 has the aft cabin and head.
Shadowfax
I believe that when PS took over Ericson the 34 became the 35-200 I also believe all the specs for all Ericsons can be found in the info, specs pages here
