K2MSmith
As some of you are aware I’m in the process of replacing my rod rigging ( with a rigger ) and doing several mast upgrades at the same time .
The 33RH has a big mainsail / rig and a relatively lightweight keel so it can become overpowered with a lot of weather helm easily with small crew and the winds we have in the Bay Area . Of course , reducing and flattening the sail is done frequently in the summer . The rigger is also suggesting reducing mast rake which moves center of effort of fail forward , reducing weather helm .
That all sounds reasonable but that requires more adjustments ($$$) to the mast step and i worry about shortening the forestay and jib sail fit .
I would especially be interested in hearing from any E33 owners in this topic. ( all 3 of us ? or anyone with any experience . I’ve also messaged Seth .
For example , what is your current rake measurement? It’s easy to measure ( estimate) by removing tension from the backstay and letting your main halyard hang . Measure the distance from the halyard line to the mast at the deck . It would be interesting to know what other E33’s sail with.
Thanks in advance!
Thanks in advance!
