I have a 1983 E28+ that needs a new cutlass bearing. In looking into doing that job it appears that there is some play in the strut so it needs to be tightened up. There is no way to directly access the nuts on the ends of the bolts that hold the strut in place as they are glassed in. Should I grind off the fiberglass on the outside to get access to the bolts in hope of being able to tighten them? Or is it better to work inside the boat and grind out the glass to gain access to the nuts and try to tighten things up from there? Any advice on how to approach this would be greatly appreciated.
