With my 1983 E28+ is on the hard again until next Spring I noticed that the strut that holds the cutlass bearing (through which the prop shaft passes) is ever so slightly loose. The shaft does not move in the bearing, the entire strut moves a bit if I push back and forth. There are some fine cracks in the area immediately where the strut attaches to the hull. Sometime before I launch next Spring I would like to get that strut strengthened up as it can only get worse with vibration over time. Has anyone ever removed and remounted (or even reinforced) this strut? Is it screwed into the hull or just glassed in? Any ideas as to how best to approach this? Thanks in advance for your thoughts.
Gary
Gary
