I finally installed a tach on my 1973 E27 (with original Atomic 4) I've had for 20 years! Tried it out the first time yesterday.
Idle reads around 600 RPM, which sounds about right. Behind the breakwater in calm water I was doing a bit over 5 knots at 1250 RPM. This seemed like low RPM for that speed to me.
Is this reasonable? What is normal cruising RPM at sea (not in the harbor) for you other E27 owners?
I think the original owner said he'd replaced the stock prop, but I don't know the specs on the current one.
