I need to replace the sheaves on my '76 E27. I will also the be converting to all-rope halyards. I have already received a quote from Zephyrwerks.
I'd like to do the work with the mast still standing.
My plan is to climb the mast using a Top Climber and one of the halyards. Then drill a hole in the mast head itself, attach a large shackle and run a line back down to the mast base and use this line to climb back up. Then theoretically I can pull the axles, remove the old sheaves and install the new.
Is this possible? This is how the current topping lift is installed.
