E27 Galley Sink Removal
Tyler Donley
Hi everybody,
I was wondering if anybody has ever tried to get the galley sink out of an Ericson 27 (or similar). The sink is so deep that it needs to be lifted straight up but there isn't enough clearance due to the pitch of the hatch. I've included a photo.
Any help would be greatly appreciated, thank you!
Mark F
Hi Tyler,
Welcome to the forum. As I remember when removing the sink you do have to scrape the back flange of the sink on the companionway lip to get it out. It is possible. Why are you pulling the sink?
Tyler Donley
Hi Tyler,
Hi Mark,
Thanks for the reply. I'm replacing the counter surface and trying to do a thorough cleaning of the galley while I'm at it. I've tried to muscle the sink out but I can't seem to get it, even scraping up against the companionway as you mentioned. I've taken every other component of the galley out and this is the last part I need to remove.
Extend the sink cutout with a jigsaw? You're replacing the countertop anyhow.
Some of these issues come up because the factory installed furniture before the deck was put on, and radical means becomes necessary.
Mark F
Hi Tyler,
I would keep at it - I think I remember having to pull it out to a point then push one side down while pulling up on the other side. Try lifting the aft starboard corner first. You might have to get it jammed - partially removed then tap down on the forward port corner and tap up from below on the aft starboard corner. I do remember it being a bit of a bear.
What are you replacing the counter top with?
Tyler Donley
Hi Tyler,
Mark, I took your advice and managed to get the sink out with brute force. Unfortunately damaged the sink a little in the process. No biggie. Thanks so much for your help! As far as replacing the counter I'm not entirely set on anything yet - I wanted to go with something dark. Do you have any suggestions?
Mark F
Sorry to hear about the damage, hope it's not too bad. If you search this site you will find some examples of what people have done over the years with their counter tops. Best to search the site using Google and ericsonyachts.org in the search. I got a little carried away and used Corian. I have an album in the "Community" section of this web site, Lotus Flower E27 Interior Remodel - http://www.ericsonyachts.org/infoexchange/album.php?albumid=267
Gary Holford
I don't recall having too much trouble with mine when I did it. A heat gun was handy, I remember that much. While I had it out I added some insulation to the side of the icebox, rebuilt the plumbing and painted interior surfaces white.
BTW, beautiful job Mark.
Gary Holford
Not to take anything away from this incredible resource and home of giants but there is also a E27 Facebook group that compliments this site in it's own way. Best of luck with the renos.
I had similar difficulties and worse, when I renewed the countertop the sink would not fit back in. I had a local metal shop zip a quarter inch off the back flange and the problem was permanently solved.
Mark F
I was hoping Doug (bigd14) would chime in. I thought I remembered Doug modifying his sink to get it back in.
I remember doing something similar to Christian's suggestion - cutting the existing countertop to more easily fit the sink. Pretty sure my approach was to cut the back side of the counter cutout on an angle so I could slide the sink in on an angle.
