how much water are you getting out of your exhaust system? It should be a decent amount - not a trickle, but a either a more or less constant flow or alternating between not much and a then a big splash, but either way, it should be flowing. There isn't apt to be anything beyond the water lift muffler, and from the point of where the water is injected into the exhaust system, it should be cool enough to touch. In fact, I can touch my mixing elbow on the side that has the water injection into it. Beware that if you are not flowing enough water and touch that mixing elbow, you will get burned. So, try disconnecting the water hose that goes into the mixing elbow and see what type of flow you've got. If it flows well, and you reconnect and have minimal or no flow, then I'd be looking at the mixing elbow being possibly clogged. There are other things that could be going on, but this would be a reasonable start on narrowing it down.
