Hi all,
I was sailing along yesterday when I heard a rythmic "thup-thup-thup" sound coming from under the cockpit sole. Thinking that my transmission was out of gear, I checked the transmission handle and found that it was in forward. I moved the handle to reverse and the noise stopped. Only now the handle would not go into neutral or forward gear.
Thinking that this was not right, I checked below. I found and touched the transmission lever, and suddenly the handle would go between forward and reverse. But I could see that the shaft was spinning when I was in forward gear and neutral, but not when I was in reverse. Under power the drive shaft behaved as I expected, and I didn't have any problems when I was motoring back to my slip.
I have a 16-hp Yanmar diesel that I think is original, and I assume that it has the transmission that came with the boat.
Can anyone explain what I was seeing, what I did wrong to make it start happening, and how much it's going to cost me to fix it?
Thanks for your help,
Chuck
Chuck
