Yes, it's fir replace lines between tank and engine. Rigid copper lines still been legal and way less expensive than hoses.
Interesting that it's still "legal"..... I know that our surveyor does not like it.
Our '88 boat was built with a copper supply line and a reinforced hose return line. I replaced all of the fuel system hoses/lines over a decade ago. The new hose, presuming you also use USCG approved hose, is multilayered and certified for both supply and return.
Lots easier to install, also,
The OEM copper in our boat looked like it had been pulled thru, from the tank, by an over-caffeinated person and was really bent & beat up.
I would advise, if anyone were to ask, to change over to hose. Double clamp all ends. In comparison to copper flare fittings, which I have done in a past life, the hose solution is lots easier. I do not know how the cost comes out. I was concerned with longevity and ease of installation. Also, that copper needs extra protection against chafe and especially vibration -- much easier to protect hose where it passes thru compartments and bulkheads.
Isn't "boat yoga" Fun!
