Kim Schoedel
The forward dorade's (these are the 2 just forward of the mast with an open box in between them). I was scrubing out the box while doing a good wash down and noticed that the water inside was NOT draining out. I can see two small drain holes at deck level on the aft side of the box and 1 hole on each end (port and starboard) at deck level. Took a piece of wire to a couple of the drain holes from the outside in and expected the wire to appear inside the box. Nope, didn't happen, the wire just stops as if it goes into some hidden chamber on each end of the box. Wonder if the drain holes have been covered with some attempt to "seal" the inside of the box by a PO.
Am I missing something here? Please advise and thanks.
