Diesel engine cooling fluid
Captainpeter
I am wondering what folks use for the fresh water cooling circuit in their diesel engines: 1. Pure antifreeze, or 2. 50/50 mixtue of antifreeze/water, 3. other. Peter
Steve
Never gave it much thought, - 50/50
50/50 provides the max protection from boil or freeze, why use anything different? This has always been the case with auto gas engines, now maybe my mind set should be differnt for a marine diesel, if so I would like to hear from an expert on this?? otherwise this has always been the mixture of choice.
I use 50/50, as advised by the small print on the antifreeze container. I also use the non-toxic "Sierra" brand, just in case the heating loop in the hot water tank ever leaks...
(M25XP Universal)
Robert Mann
Oddly enough a pure 100% anti freeze mix will not protect to as low a temperature as the 50/50 mix.
Bob Mann
Wind Warrior '88 E26
