Hi,
I think I might have an answer for you indirectly from the Ericson Sailnet list back in 2003. I pulled this out of my archives of emails on stuff I thought worth keeping. I was not the original poster, this is from a contributor named Walt who had/has an ’88 vintage E32-200:
"Apparently, there is an aluminum strip about 2 inches by 5 inches and located under the gel coat and just under the recessed deck/gel coat area that receives the sliding anchor locker door bolt. The stainless fitting that arches over the deck recession/door bolt retainer is held to the deck by two stainless screws that ultimately screw into the hidden aluminum strip. This I believe, caused the reaction and the aluminum oxide which erupted the deck. There was likely some seawater that leaked either through the retainer fitting screws or the anchor locker insert lip or one of the anchor locker insert screws, to activate the chemical reaction."
Hope this helps. If I remember correctly, Walt ended cutting the area out and redoing it. Sounds worse than it is
-David
Independence 31
Emerald
