Christian,
Going by the bare data we have, the Ericson has a shorter roll period estimate than the Westsail, this indicates that the Ericson is stiffer than the Westsail (i.e. the Westsail is more tender than the Ericson).
However, you know your boat! So is this the case in reality?
Perhaps if we turn the viewpoint around a bit and you compare your Ericson with the Mumm 30 you'll see the results reversed. The Ericson becomes the more tender boat. Would you agree that this is correct?
Regards
Paul
I am not sure of the exact NA usage of some terms, but have always understood that "tippy" is, for us average sailors, a shorthand way to describe low initial stability. I think of this in terms of 'slack bilges' and 'hard bilge chines' in smaller cruisers.
Ancient history note: In the late 70's we raced our Ranger 20 in a OD group with a class of Catalina 22's. The C-22 was more stable-seeming when you stepped on the deck, and the R-20, was "tippy" in comparison, having very slack bilges.
These different designs got their 'final stability' from hull form -- the Catalina liked to be sailed much flatter and the Ranger was designed to sail at about 15 degrees of heel, having a hard chine in the hull side well above the waterline. Both were very capable pocket cruisers for a couple.
The Westsail 32 and a related design from Crealock, the Willard 30 cutter, both have roundish bottoms and slack bilges. I have done a number of ocean deliveries on the Willard and can testify that it rolls a lot at sea. Built like a tank, and rather slow. This is reassuring to the owner (and crew...) but it is different than my Olson. I have a lot less wetted surface and a flatter run aft and of course a transom stern. That's were we get our double digit speeds off the wind.
I have one ocean delivery on the Ericson 32-3 model. while it has enough "tuck up" in the stern sections to confine it to displacement speeds, it also has more V to the forefoot than our design and is quieter in lumpy seas. It is a
great compromise in design elements, IMHO.
Gotta say, referencing the Mumm is like comparing road race vehicles like a SR mid engine car to a sedan-derived race car like the Volvo 122S I used to own.
The family sedan could actually function as an everyday family car again if you removed the roll bar, but the SR would fare very poorly for camping trips!
And boats like the Mumm and the similar Olson 30 and Santa Cruze 27 have about as much accommodation as a.... Catalina 22.... !
I get your point about comparing some of these disparate designs to establish the length of your "tippy" scale.
Interesting discussion.
Regards,
