treilley
I finally assembled my completed binacle today(launch on Tuesday)
I removed the binacle and stripped it to bare metal and then had it powdercoated. I made a new plate out of starboard and also had a new guard fabricated. All wires run down through the binacle. I also had my compass rebuilt. Replaced the transmission cable and now it shifts like butter. The final result is a helm station that is better than new.
I adjusted my steering and added a rudder postion sensor and now I can spin the wheel and it will keep turning. I hope to be able to get some better feedback as a result. Previously the steering was so stiff that you could set it anywhere you wanted and even a big puff wouldn't budge the wheel. When down there I found many of the sheaves where not aligned and the cables were way too tight.
We also took the opportunity to polish and wax the lower part of the cockpit as it was much easier to do without all the steering gear in the way.
