Joe Benedict
Sorry - jumping in late here. I had/have the same annoying leak which has had a few sources. The larger leak would only "appear" when there were a lot of people in the boat or on a fairly rough day. The source was the "T" fitting for 2 of the cockpit drains. The "T" is lightly over the water line so it does not leak all the time. Check out the plumbing specs on this site for the E27 - it isn't part of the E29 stuff. You can see one of the "T's" through the port side cockpit hatch - some difficulty. The second source is cracks in the void section of the sump in the rear part of the keel - got most of them last year but must have missed one - don't store the boat on metal or with all of the weight on the aft part of the keel. For peice of mind I put an automatic pump in the sump access at the ladder - just slung off a simple frame and routed allong side the manual pump to it's own discharge - with a loop.
