Rocinante33
This weekend I was in the process of wrapping up a long & tedious series of projects. The last of these was changing hoses to the engine (Universal M25). Upon completion, I turned the marelon ball valve for the seawater inlet. It resisted, then gave way & seemed to turn too easily. The shaft to the handle had broken. No water came through when I started the engine. It is in the closed position. It is probably a factory original.
We just had the boat hauled & bottom painted. I would rather not haul it again just yet. I would rather defer relacing it with a proper seacock until the next haulout.
This is what I propose to do:
1. Call Forespar (Marelon makers) to check feasability. Can I do this as far as they are concerned?
2. Dive the hull & lightly drive a soft wooden plug into that thruhull. Allow it to soak & swell for an hour (or even overnight?).
3. With additional wooden plugs standing by, remove the bad ballcock from the thruhull threads.
4. Replace it, sealing the threads as I do so.
5. Inspect carefully to ensure that the thruhull has not spun or otherwise begun to leak.
Sanity check----over
Keith
E33
Keith
E33
