Mort Fligelman
I have gone through all of the threads I can find on the Lewmar Opening Ports.......
I followed the advice on one to call Catalina Direct for the Lenses and Gaskets, which I did, and ordered one gasket and one lense to make sure that they will work.
I copied the article from Yachtworld and removed one latch and proceeded to try to get the correct size "O" ring.......found this to be a real problem.....everyone has them in pre-packaged bags which you cannot just try for fit.....I bought four different ones....they will all work if they are a bit oversized, but the latches require enough effort to make me think that it will eventually do some damage.....even with a glob of silicone grease on them.
The bottom line on all of this is:-
DOES ANYONE KNOW THE EXACT NUMBER "O" RING, OR HAVE ALL OF THE CORRECT DIMENSIONS FOR THIS "O" RING.....
Any help would be appreciated......
Mort Fligelman
Acapella
1987 E-35-3
Mort Fligelman
Acapella
1987 E-35-3
