Hello All,
It has come to my attention due to progressively longer sailing trips that a good autopilot is a must have piece of gear. I will not install a wheelpilot. The steering system in my boat is being torn down this winter. It makes a nice groaning noise when turning to port going down wind. Rudder will be removed, bearings checked/replaced, etc. The E38 presents several problems to autopilot installation:
The first issue is that it appears that the Yacht Specialties steering system allows more than 35* rudder deflection in each direction. This is a problem with Raymarine linear drives and requires a type 2 long drive and the requisite expensive upgraded hardware to deal with the extra rudder travel.
My YS setup is damaged. There is no rudder stop! There is a large aluminum bracket that mounts beneath the steering pedestal, under the cockpit floor that holds the sheaves, etc. for the steering system. There was a stop at some point but the stop was broken off by some PO. The quadrant will actually continue travel until it contacts the inner deck drain hoses.... Obviously not a good thing.
Lastly, there is not enough rudder stock exposed on my boat to allow a separate tiller arm to be clamped onto the rudder stock for attachment to the autopilot ram. I have seen one other E38 with a separate tiller arm however the owner claimed that this was a factory installed setup and this makes me think that the factory just made the rudder post tube just a bit shorter when it was built.
So here are my options as I see them:
With no way to attach a tiller arm I will have to do a modified quadrant ala CaptRon. He used a plate of aluminum with a starboard spacer to create an attachment point for the linear drive. Shouldn't be a huge problem to get this made.
To deal with the lack of rudder stop I can remove the damaged aluminum bracket and either bolt or weld on a new stop. The good thing about this is the size of the rudder stop can be adjusted to limit the rudder travel. I have read that travel beyond 35* is non-productive so the stop could be built accordingly. This should also allow the use of the less expensive Raymarine linear drive. I couldn't find any info on required rudder travel for any of the other autopilots, Comnav/Nexus, B&G, Simrad, etc. so I have to assume they will expect 35* deflection maximum as well. Figuring the rudder travel, etc. should be easy with the parts on a work bench.....
I originally had a Comnav/Nexus autopilot as the top choice. The prices recently however have increased astronomically. The Nexus is now $1000 more than when I first priced it. Others have increased as well. Raymarine, even though I am not the fondest of their gear, has remained the most affordable. I have also been walking the docks and talking to belowdecks Raymarine owners and then have all been pretty satisfied with their units. I don't think I can swing the autopilot this winter unless I go with Raymarine.
So what I am asking is for any input regarding the actual physical installation of the ram/linear drive on the steering system of an E38 or similar. The steering system needs attention and I would much rather do the autopilot while its all apart and not have to dig into it again next year. Thanks, RT
