Greg Kruse
I've recently completed a wiring harness replacement on my 1990 E32-200/Universal M25XP. I was originally inspired to do this due to intermittent tachometer function as well as intermittent starter button failure...(ie. push button, no start). I also bought new gauges and re-fabricated my cockpit control panel. New tach, temp guage, volt meter.
After landing all wires in engine compartment and at the cockpit controls, I was psyched to hear the engine turn over and start immediately! Partial Success.
However, my tachometer is still not working. I took volt readings between AC tap and ground and was seeing readings of around 300 mV at slow idle and around 0.8 V at max rpm. So I took the alternator into the shop and explained what I was seeing. They put it on their bench and showed me voltages closer to 6 to 7 volts, between the same AC Tap and ground. So, I decided to have them go through and work their magic with brush and diode replacement, and we decided the AC voltage issue I was seeing was possibly a grounding issue.
Short story: Alternator back place, same problem with low voltage between AC tap and ground...and tach still not registering any rpm. I've freshened up all the grounded connections with wire brush/dremel and have verified good conductivity between alternator ground--engine block--battery.
So, maybe I'm just wiring something incorrectly. I've attempted to follow wiring diagrams provided by Catalina Direct with the wiring harness replacement...and re-routing Positive Output directly to the starter post.
I've attached a simple diagram showing the business end of my prestolite alternator and how I've got things wired. Any quick glances at this for obvious errors would be much appreciated. In Lieu of some wiring misstep, are there any ideas out there as to why I'd be getting the low voltage readings at the AC Tap??
G.
G.
