Grinding it out
I took a grinder to mine and removed it, and replaced it with Grade 5 Ti bar. Grinding it out sucked in that confined space, and so did getting in and out of the aft lazarette. I found several voids where it was glassed in, with rust penetrating below deck level about 2 inches or so. The original was 1/4" thick, but I upsized to 3/8" and through-bolted the new piece to the transom after epoxying a 3/8" sheet of G10 on the inside as a massive backing plate (which I needed for the wind vane anyway).
