Hi folks,
I have always found answers to issues in this forum and currently have questions about my small 1GM 8hp Yanmar. When cold there is a few minutes of unburnt fuel(black) in the exhaust. The engine will run all day at 2500 rpms at about 4 knots. It appears to be over propped as the boat originally came with a 2 blade prop. It seems a past owner changed to a 3 blade 11-11 pitch. Does anyone know the correct prop for this boat? Also any help diagnosing the unburnt fuel and low rpms would be helpful. The engine is now 31 years old, so is it at the end of its service life? Thanks.
Bob
Cosmos Lady
E26-2
Hello, Bob.
I have the same boat (a 1984) and engine as you. When you say, "the engine will run all day at 2500 rpms" do you mean that this is the maximum you can hit? If you can't hit at least 3500 rpm with that engine (in gear) then you are over propped, or else the engine is not making its rated hp for some reason. You do need to confirm the actual engine rpm with a laser tach, by the way, because the tach on that engine is almost certainly off--though it's unlikely to be off by more than a few hundred rpm. You can obtain an inexpensive laser tach from Harbor Freight.
As for the correct pitch: When you ask, "Does anyone know the correct prop for this boat?" you are asking the wrong question. The "boat" has nothing to do with the correct pitch for the prop. In order to determine the correct prop pitch a prop shop needs to know primarily: (1) the engine hp; (2) the gear reduction ratio of the transmission; (3) the number of blades. I say "primarily" because there are certain design factors unique to certain props that can require more or less pitch. For example, the Campbell-Sailer prop generally requires less pitch than a conventional prop due to the shape of the blades. But that's something that a prop shop can tell you.
The bottom line is that it is best to call a reputable prop shop in your area and have them tell you what you need. Be prepared to give the engine hp at max rpm as well as the transmission gear ratio.
By the way: I recommend the 3-blade Campbell-Sailer prop for this engine. As it is, we have a marginal amount of hp for a 5200# boat, so having an efficient prop is imperative. I originally had a 3-blade prop with big dumbo ears. It worked fine as a prop while under power but had a horrendous amount of drag under sail. The nice thing about the Campbell-Sailer prop is that it is very efficient for a 3-blade fixed prop and has much less drag under sail. With the same engine as you have, I typically motor at 5.2-5.4 knots at about 2900 rpm. This is comparable to my previous "Dumbo-eared prop" minus much of he drag. This June I'll be swapping out my 1GM for a 1GM10, which I got off of eBay for an excellent price. (It had been run only in fresh water and was rebuilt not that long ago.) The 1GM10 adds a couple of hp, which is significant when you are talking about as little hp as our engines have. I'll be sending back the prop to have a little bit of pitch added to it, in order to take advantage of the extra hp.The company that makes the Campbell-Sailer prop offers outstanding tech support and they can really answer all your prop questions. (By the way: They do spell it "Sailer" for some reason.)
For an excellent review of the Campbell-Sailer prop by the very reputable Maine Sail, see:
http://forums.sailboatowners.com/index.php?threads/prop-review-campbell-sailor.112587/
