mangosnrum
I recently purchased a 1969 Ericson 23 MK1 and it needs, well, everything. I will be refurbishing this boat into great shape, but for now I need to know if the hull of this boat is solely fiberglass or if it is glass and marine ply and if so, how thick the hull is. I need to install new ribs on the forward starbord side (5 are currently missing, Im assuming they were bad and got torn out by someone with greater intentions than motivation) but the inner fiberglass walls are in my way. It would make my life much easier if I were able to screw into the hull with short screws, glass over the ribs, grind the screw heads down a bit and glass over them to hide them. I believe the hull is glass/marine ply, but does anyone know the thickness of it? I would hate to punch through but I need to get those ribs replaced to maintian the hull integrity. If I cannot use screws (or even if I can), what is the best way to go about this step? I have pictures I can post soon.
