GrandpaSteve
Hello,
Boat is hauled for the winter. I was going to do some work aboard, and used an adapter to connect my shore power connector to the utility post at the yard (about 100' away). As soon as I turn my main breaker on my AC panel on, the GFCI trips on the utility post. Tried a couple of other utility posts with the same result.
I understand GFCI, and I understand that I have not made any AC modifications to my boat.
As a short term test (I did not leave it in place) I lifted the ground on the utility post with a three to two prong adapter that happened to be available on the utility post. In that configuration (no ground), the GFCI did not trip when I powered up my panel.
I continued to do my work by using an extension cord and not powering my AC panel on the boat.
Last Spring I worked on the boat from a non-GFCI utility pole without any problems. I had no shore power problems over the Summer either.
I have read that the polarity check circuit can cause this situation, and the only way to resolve it and keep a ground in place is to disconnect the reverse polarity light. Does anyone have any experience with this?
Also, in normal operation the GFCI outlet on the boat does not trip and it tests fine (test button).
Steve Pretti
1987 Ericson 32-3 Glory Days
Steve Pretti
