Sven
Seglare
I left the 12-volt bible on board, so I can't look it up :-/
What is the best way of installing an unpluggable 12-volt device ? A screw terminal block that you unscrew every time you want to remove the device ... banana plugs ... ?
I expect to be removing the wooden side panels in the cabin from time to time to make sure the stanchion bedding isn't leaking, but that also means disconnecting the light fixture, right now I have to cut the wires every time.
Suggestions ?
Thanks !
Suggestions ?
Thanks !
