I have a 1985 Ericson 32 with a Universal xp25 engine. I have been updating the boat over the last two years of ownership including the 12 volt system (agm batteries, Balmar charging system and charger / inverter,) new electronics (Raymaring C80 radar / chartplotter), standing and running rigging, sails (new summer jib for the wild SF bay and cruising spinnaker) plus many, many other upgrades. I am so pleased with the design, construction, and sailing performance of this boat. The previous owner did many cosmetic upgrades including new interior, dodger, and anything pretty. Overall the boat is in unbelievable condition for a gal of her age. But....
I have been plagued with an overheating condition. When I first bought the boat I had a real handy neighbor help with upgrading the mechanical systems. We installed a fresh water filter on the cooling intake, installed a Racor fuel filtering system, and of course changed all of the fluids. I recently sent a sample of the oil (6 months old) to Blackstone for testing. The results came back with great results it every area with the final coment, "Great engine condition." Initially the boat would overheat if I ran it full throttle (2700 rpm) for more than 10 minutes. Since I rarely needed to max the throttle (it is a sailboat afterall) this was a minor concern. However, lately (this weekend specifically) the boat is exceeding 180 degrees after running at cruising rpm (2ooo rpm.) after 40 minutes. The water intake filter is clean, I just changed the oil and coolant, the water pump impeller is new, and it still heats up at cruising speed.
I am thankful that the Blackstone Oil Analsys came back with smiley faces but I am at a loss as to what to do next. I am not a diesel mechanic but do like to do all of my own work. Should I throw down the glove and hire a mechanic or do any of you have suggestions as to where to go from here. I thought maybe the head exchanger needs to be boiled out but that is just a guess.
Please lend me some expertise in this very difficult area.
