Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: Another outboard...
  1. #1
    Contributing Member I
    Join Date
    May 2019
    Location
    Oakland estuary
    Posts
    19
    Another outboard...
    I decided replace my tired Volvo MD7a plus saildrive with an 15/20 hp outboard.
    Can I remove the saildrive and hang there the outboard?? That avoid install an outboard external support in the back.
    Maybe I lost the possibility to serve the transmission but I win on the weigh/displacement location.
    I just want to explore the possibility before hung +100 pound on the back of the boat
    Like always, thanks in advance! Every answer is appreciated it!
  2. #2
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,743
    Blog Entries
    66
    IF..... you had the factory outboard motor transom model of the E-27, this thread would be helpful.
    http://www.ericsonyachts.org/infoexc...&referrerid=28
    If you have to do the cut-out and inside reinforcement, you have an interesting project ahead. And, do not even think about bolting on a bracket. This puts the motor too far down from the top of the transom, and you would *still* have to heavily reinforce the transom to take the load. Also, a bracket mount puts the motor back of the stern wave too far and the motor will, in steep seas, either pop the prop out or bury the powerhead.
    If keeping boat for another decade, install a new Betamarine sail drive unit.
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  3. #3
    Join Date
    May 2019
    Location
    Oakland estuary
    Posts
    19
    I asked for a new betamarine with saildrive... $14K.. I'm going the outboard path.
    Yes. my ericsson have the cut off.. maybe reinforce before hang almost 100 pound back there?
  4. #4
    Principal Partner
    Join Date
    Sep 2013
    Location
    Port Angeles, WA
    Posts
    892
    15-20hp would be way overpowered. 8hp should easily give you hull speed +. You don't want to consentrate too much weight in the very stern of the boat. It will negatively affect the sailing ability of the boat. Do you know how you would fill that large hole in the bottom of the boat when you remove the engine? Have you considered a rebuild of the engine? Those old diesels practically last forever.
    Bob Morrison
    1987 E-34 Hull #15
    "Terra Nova"
  5. #5
    Join Date
    Dec 2000
    Location
    Posts
    7,743
    Blog Entries
    66
    Question Choices and options
    Quote Originally Posted by supersailor View Post
    Yup. A modern four stroke 8 or 10 hp OB with the 25" leg would be enough. Just clamp it to the transom cutout, and "no way no how" have it cantilevered out on a bracket.
    And, as noted, filling in a large hole in the bottom of the boat is a significant ($$) project in itself. I imagine that a yard could do in two days total, maybe more. That's one guy @ $115./hour. If it takes three days you're at about $2700. plus at least 200 or 300 for the round trip and blocking.
    While I am no fan of sail drives or Volvo's, repair might be a lot less expensive. Admittedly, the older actual-Volvo-built engines are more reliable compared to the new re-labeled products.
    Opinions rendered on the hour, deposit 2 cents please...
    1988 Olson 34 #8
    Sail # 28400
    Fresh Air
    Portland, OR USA
  6. #6
    Join Date
    May 2019
    Location
    Oakland estuary
    Posts
    19
    My son is allergic to diesel so rebuild was out of question.
    I play with the idea replace for an electric solution, very easy for me as engineer but when I finish adding batteries, charger and all "little things" you need to add in order to do a up to code installation, price was not very far from a new betamarine with saildrive.
    Outboard was my last option. I agree less than 10 hp is enough but I prefer has power when I need it and not miss it.
    My ericsson have the cut off to install an outboard so well.. I'm selling the old volvo engine
  7. #7
    Join Date
    May 2019
    Location
    Oakland estuary
    Posts
    19
    Quote Originally Posted by Loren Beach View Post
    I would cover with an aluminum plate for now and install both batteries down there or maybe use for the gas tank in a more permanent installation. I can do that for myself.
  8. #8
    Principal Partner
    Join Date
    Sep 2013
    Location
    Port Angeles, WA
    Posts
    892
    It may cost a lot less to sell the diesel boat and buy an outboard powered one. It would certainly be a lot less work.
    Bob Morrison
    1987 E-34 Hull #15
    "Terra Nova"
  9. #9
    Join Date
    Dec 2000
    Location
    Posts
    7,743
    Blog Entries
    66
    Question
    I might be misunderstanding the proposed solution, but if an aluminum plate is glued or glassed into the bottom where the sail drive used to live, both the insurance company and any surveyor are going to be quite unhappy. Aluminum - depending on exact alloy - will corrode quickly or slowly in salt water.
    1988 Olson 34 #8
    Sail # 28400
    Fresh Air
    Portland, OR USA
  10. #10
    Principal Partner
    Join Date
    Sep 2013
    Location
    Port Angeles, WA
    Posts
    892
    My proposall is to sell the current boat intact and take the money and buy an outboard powered boat. The outboard powered one should be worth less. There is no money spent repairing the hull and buying an outboard for the current one. Also no rebuilding needed on the new one. It appears that many thousands can be saved along with many weeks of labor.
    Bob Morrison
    1987 E-34 Hull #15
    "Terra Nova"
  11. #11
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,251
    Blog Entries
    78
    Agree completely.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  12. #12
    Join Date
    Apr 2017
    Location
    Boston - Maine
    Posts
    127
    Well, the price he gets selling the current boat will be depressed by it needing a new engine so he'd be paying for the new motor for his old boat that way anyway, at least in part if he were to swap it for an outboard motor. [edit - I see from another post that his engine is actually running OK, so agree, sell and get an outboard (or Atomic-4 powered!) boat.]
    Depending on how you use the motor I would think about revisiting the electric conversion. If your saildrive is in OK shape it could be adapted to electric drive and you don't have to start out with the largest battery capacity. You can add capacity as you need it and save for it. yes the initial expense is still a lot but if you can solar / dock charge and use your motor for just getting in and out then it might actually be a better value down the road. Or even do a hybrid: small outboard in the cut-out and electric motor with small battery. that way you start the outboard for the long motors only.. etc.
  13. #13
    Join Date
    May 2019
    Location
    Oakland estuary
    Posts
    19
    Quote Originally Posted by debonAir View Post
    Well.. in the moment boat is ready, I will put for sale. On my experience, sometimes people "fall in love" with the boat. I can use for years to come but definitely will put for sale.
    With new standing rigging, new outboard, bottom paint, deck paint and rewire with LED light plus new lewmar hatches, I think it's gonna be a good deal for somebody.
    There are a lot of depleted boats (even at my marina) I could rebuild or get for free.
    But for now, this is the project. Noted the thing about not use aluminum... stainless 316 then.
    The engine is for sale here at the forum and by craigslist. Price is $2500 but if somebody willing to help me to remove it, I can cut a reasonable part. Engine has a new alternator but not panel, I remove it and was in very bad shape. For the right price, I can do one for cheap, even I can add a NMEA2000 system in order to check all engine parameters from your chartplotter.
  14. #14
    Join Date
    Dec 2000
    Location
    Posts
    7,743
    Blog Entries
    66
    Red face Problem Smell......
    Quote Originally Posted by Sailingfun View Post
    In reviewing this thread I realized that I was puzzled by the reference to an allergy to diesel, that seemed to be provoked by the presence of the diesel engine.
    Unless the present engine has a lot of blow-by, or a leaking fuel system, there should not normally be ANY smell of diesel in your boat.
    Our former (worn) diesel engine did have blow-by, and the engine exhaust blower removed it handily.
    If there is any (at all) odor of diesel fuel inside of the boat some trouble shooting of the fuel system including the tank and the fill hose needs to be done.
    I wonder if any or all of those parts has been serviced in the last ten or 15 years?
    Anyhow, just something to ponder.
    And no, we have no (zero) diesel smell inside of our boat. Most of the boats I have crewed on for deliveries in the last 30 years have not had that odor, either. (Some of them had other more-complicated problems, tho...)
    1988 Olson 34 #8
    Sail # 28400
    Fresh Air
    Portland, OR USA
  15. #15
    Join Date
    May 2019
    Location
    Oakland estuary
    Posts
    19
    Definitely nobody run a good maintenance engine on the last 10 years at least.
    Will think about it
    Thank for your suggestions
Similar Threads
  1. 25 Plus Outboard
    By donnie10f in forum Maintenance & Mechanical
    Last Post: 09-09-2019, 02:06 PM
  2. Outboard Woe's
    By Jeff Asbury in forum The Raftup
    Last Post: 09-30-2013, 09:43 PM
  3. outboard for E-25?
    By raslocum in forum Maintenance & Mechanical
    Last Post: 10-26-2007, 01:50 PM
  4. Most of an outboard $15
    By Ernest in forum For Sale & Wanted
    Last Post: 11-02-2006, 02:57 PM
  5. 8hp outboard
    By Jeff Meier in forum For Sale & Wanted
    Last Post: 10-17-2006, 01:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
