1987 Ericson 38-200 For Sale
Drewm3i
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_0.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_1.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_2.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_3.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_4.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_5.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_6.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_7.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_8.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_9.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_11.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_13.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_15.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_19.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_21.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_23.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_27.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_28.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_29.jpg?t=1565463874000&w=1200&h=1200
https://images.boats.com/resize/1/91/98/7179198_0_100820192050_30.jpg?t=1565463874000&w=1200&h=1200
For Sale: 1987 Ericson 38-200 Cruising Sailboat,​
Designed by Bruce King as a Performance Cruiser​
The boat has just undergone an extensive refit, but change in life plans force sale. You can either buy a similar classic boat and spend months and tens of thousands of dollars in a boatyard as we did, buy a newer but inferior boat for a lot more money, or buy this cruise-ready classic. I have receipts, pictures, and invoices for the work that has been completed!​
  • Refit 2018-19 Highlights​
    • Standing Rigging Replaced​
      • Port intermediate and cap shroud chainplates also replaced; have custom Garhauer u-bolts to replace the rest​
      • Headstay chainplate removed, inspected, and bolts replaced with new​
      • Backstay chainplate removed, inspected, and re-bedded​
      • Mast painted with polyurethane paint while on the ground​
    • All New Electronics in 2019!​
      • Brand New CPT Autopilot steers the vessel with ease in any sea​
      • Brand New B&G wind speed, direction, and depth instruments with Triton T41 displays, thru-hull transducer, and wireless ws320 wind transducer, installed on a nmea2000 circuit protected by TVSS.​
      • Brand New Garmin HD+ 18” Radar and 942xs touchscreen GPS/Chartplotter/Fishfinder combo, which integrate with the ship’s nmea2k network​
        • Secured to brand-new seaview radar mount riveted to mast​
      • Brand New Garmin 210 VHF Radio w/ AIS and nmea2k, protected by TVSS device and coaxial gas-block surge protector​
    • Full Bottom Job, with existing blisters repaired properly utilizing biaxial fiberglass cloth and West System Epoxy​
      • Afterwards, faired with 404, sanded smooth, and painted​
      • Painted with Petit multi-season ablative paint​
      • Shaft anode changed​
    • Manual anchor windlass added, ground tackle overhauled​
      • Anchor locker pan was beefed up with plywood coring coated with fiberglass and epoxy​
        • Plywood reinforcement added to deck flange where pan is screwed down into​
        • Result is pan is so strong now that multiple can stand in it!​
        • Foam insulation also added underneath pan to insulate front cabin​
      • 55’ of 5/16” galvanized chain spliced to 200’ of 3/4” three strand nylon rode to work with windlass and 35 lb. Bruce Anchor​
        • Anchor chain is now stored below the pan where it drops freely into an integrated chain locker, accessible from the front v-berth​
      • All penetrations through pan and flange were drilled out and filled with epoxy and then sealed with butyl tape​
    • 3-blade Bronze Propeller reworked, balanced, and polished by General Propeller in Sarasota, FL​
      • Increased speed under power by over 1kt!​
    • Engine Serviced​
      • Oil and filter changed​
      • Fuel filter changed​
      • Impeller changed​
    • 1500W Pro Mariner True Power Plus Inverter Added​
      • Installed to 3x 100aH AGM batteries​
      • Fused properly and installed with properly gauged wire​
    • 3x 100w Renogy Solar Panels added along with 20 amp charge controller​
      • Installation uses oversized wire and is fused for safety​
      • Panels are secured to stainless steel dinghy davits with stainless steel fasteners and custom-built frame​
        • Davits were through bolted to hull and beefed up to hold the panels and a heavier dinghy and outboard​
    • Running Rigging renewed where needed and otherwise in very good condition​
      • New main halyard​
      • New reef 1 line​
      • New reef 2 line​
      • New dyneema topping lift​
    • Lifelines in good order​
      • Two replaced due to hairline cracks in swages, others had been replaced prior​
    • Sails inspected and repaired where necessary by a reputable sail loft and deemed to be in exceptional condition​
      • Include fully-battened mainsail, 135 Genoa, and asymmetrical spinnaker​
      • Genoa UV strip just resewed​
    • Brand new LED foredeck, bow, and stern lights installed​
      • All cabin fixtures fitted with LED bulbs​
    • Outside and inside continually cleaned and polished​
    • All opening ports resealed with new weather stripping​
    • Custom shower sump built and new pump added​
    • Brand new curtains sewn and fitted​
Also includes for full asking price:​
2003 Avon Ultra-Light 3.10M Hypalon Fiberglass Rib​
with 2017 Mercury Four Stroke 9.9hp outboard!​
  • Full Equipment List​
    • Mechanical​
      • Yanmar 35 hp diesel engine​
      • Shaft drive​
    • Rig and Sails​
      • 10 1x19 316 stainless steel stays​
      • Fully-Battened Mainsail​
      • 135 Genoa​
      • Assymetrical Spinnaker​
      • Two Mylar racing head sails (170 and 150)​
      • All sheets and lines lead aft​
    • Hull and Deck​
      • Hull structure is provided by Ericson Yachts Tri-Axial Force Grid, a fully molded fiberglass grid that is tabbed to the hull with fiberglass cloth​
        • Bulkheads and furniture are also tabbed to the hull and structural grid​
      • Lead fin keel bolted to hull with 13 1” stainless steel bolts​
      • Hull/Deck joint is fiberglassed together on the inside​
      • Deck structure is 100% solid with no rot or delamination!​
      • Three dorade cowls provide passive ventilation​
      • Sale includes winter cover​
    • Tankage​
      • 75 gallons of water​
      • 59 gallons of diesel​
      • 25 gallon holding tank​
    • Lighting​
      • All LED cabin lighting​
      • Brand new masthead light, LED steaming light, LED foredeck light, and LED navigation light​
    • Galley​
      • 3 burner CNG range with oven​
      • Salt water foot pump​
      • Fresh water foot pump​
      • Dual stainless steel sinks​
      • Top-loading 12v Aldour Barbour fridge/freezer combo that has been upgraded​
      • Pressurized hot/cold water​
    • Head​
      • Jabsco electric head​
      • Separate shower stall with hot/cold water​
      • Shower sump pumped overboard​
      • Manual overboard discharge for holding tank​
    • Plumbing​
      • All fittings below water line double clamped​
      • Forespar Marelon thru-fittings used throughout in lieu of corrosive metallic ones​
      • Hoses and hose clamps in good order​
      • 2 electric bilge pumps​
      • 1 manual bilge pump​
    • Cabin​
      • spacious aft cabin with shelf, closet, and book case​
      • Front v berth with dual closets, drawers, shelves, and storage compartments​
      • Large saloon with removable filler cushion that converts into berth​
        • Optional folding table attachment to increase dining capacity​
      • Cabin built with with genuine teak veneer plywood with solid teak doors, handles, and accents unlike newer boats​
        • Cabin lined with teak planks​
      • Vinyl headliner unzips to provide access to wiring and deck hardware​
      • Ten opening ports and two opening hatches provide plenty of ventilation​
        • Four large glass portlights provide plenty of light​
    • Electrical​
      • 30 amp shorepower​
        • An abundance of outlets throughout​
        • Xantrex 40 amp battery charger​
        • hot water heater, powered by 110 or the engine​
      • 3x 105 aH AGM Battery bank with dual switches​
        • Provide plenty of power for many lights and three cabin fans at anchor​
        • 1500w Pro Mariner True Power Plus inverter​
        • 3x 100w each= 300w total, Renogy solar panels and 20 amp GUI charge controller​
    • Electronics​
      • Garmin 942 XS Chartplotter/GPS​
      • Garmin HD+ 18” closed array radar​
      • CPT Autopilot​
      • Garmin 210 VHF Radio with AIS receiver​
      • 2x B&G Triton T41 displays with thru-hull temp and depth transducer​
      • B&G WS 320 Wind transducer​
    • Cockpit​
      • Cockpit drained by four large scuppers​
      • Vinyl cockpit cushions​
      • Life sling MOB flotation device​
      • Stainless steel outboard crane​
      • Stainless steel dinghy davits bolted to rail and hull​
        • Cross brace also through bolted to individual davit arms​
      • Four step swim ladder with teak pads​
      • Two large lazarette lockers​
      • Emergency tiller​
      • Teak folding cockpit table with four drink holders​
    • Canvas​
      • Sunbrella dodger with isinglass windows​
      • Bimini top that can connect to dodger​
      • Helm cover​
      • Mainsail cover​
      • Full winter cover made of Sunbrella​
      • Cockpit cushions​
    • Ground Tackle​
      • Manual Windlass​
      • 33lb. Bruce anchor​
        • 55’ 5/16” galvanized chain spliced to 200’ of 3/4” 3 stranded nylon rode​
      • 25 lb. Danforth stern anchor with 10’ of vinyl coated chain and nylon rode​
    • Extras​
      • Many spare lines, sheets​
      • Fenders included​
      • ACR beacon light​
        • Flares and flare gun​
      • Bosun’s chair​
      • Spare engine filters, belts, impellers, and other parts​
Asking $69,995.00 with dinghy included.
Located in South Florida.
Drewm3i
1987 Ericson 38-200 For Sale - Images
Drewm3i
Still for sale, may even consider partial trade for a smaller Ericson in similar condition along the East Coast, US.
rbonilla
"don't tread on me" member XVXIIIII
good day...can you e mail me a pdf survey done within the last 12 months ? thanx...Richard / Colorado
