Asahi Valves
Filkee
This is the non-functional Asahi valve which were it working, would control my starboard water tank. DE01529D-9F2B-4103-95B8-441B87260653.jpg
Does someone have a good line on a vendor to replace or would I be okay just using the $2 option from the hardware store? I like $2 answers.
Looks like you get 2 of them for about $30, which isn't too bad.
I suppose hardware store irrigation valves would work OK, but are they compatible?
It's a low pressure water system, no big issues.
Filkee
Low Pressure
Good. Might go for OEM but if it’s not going to sink me I might replace all three with the True Value solution.
Pat C.
I used to see them sold at Lowe's, now most everything is a PEX fitting. You should be able to use a PEX fitting to replace it with.
