I posted in 2010 re replacement of my transmission which was persistently slipping out of forward gear. Replacement unit was a Hurth ZF10, I believe a rebuild (my notes are unfortunately skimpy). The new unit has now developed the same problem and the recommendation is replacement.
The yard is saying that the ZF 10 is no longer available, and that they would put in a ZF 12, which is larger and may require shortening the shaft.
Questions:
a. Does anyone have a line on finding a ZF 10?
b. Are there alternatives to this type of transmission that may be more reliable and are not so large as to require shaft modification? I'm finding that the Hurth reputation is less than stellar.
Questions:
