Spar manufacturer for 1974 E27
Kittery Yard
Thank you Mark
Thank you for the help Mark, I have a call into Rig Rite/Kenyon Spars and will go from there. I will keep you posted!!
dt222
From a PDF of the owners manual that looks to be dated 12/77:
Mast & Boom (23, 25, 27 only)
Sparcraft
Pox 925
Coasta Mesa, CA 92627
714/645-7177
DOn
Guy Stevens
Sparcraft is long long gone
Todays Sparcraft has nothing other than a name to do with the original sparcraft.
Facnor own them part of the Losange Group out of France.
Guy
I know of at least one Olson owner very pleased with this spar builder for a replacement mast. I believe that there are some Ericson owners who have posted here about using this company as well.
http://www.ballengerspars.com/
Phil MacFarlane
Ahh yes Buzz Ballenger. He has helped out many a single handed Trans PAC racer who turned up in Hawaii with broken booms and in some cases masts.
I'll probably go with him. He's very close by. I just was surprised that I might be able to order the exact mast that came on my boat 43 years ago from the same company!
Thanks again
Phil
Seth
weLl-not quite
Thanks again
Phil
What you would likely get from Buzz is something better. He will look at the specs for the original spar section, and use something which meets or exceeds those characteristics. You will end up wth something which is probabaly smaller in cross section, lighter, and stronger than the original.. He MIGHT be able to track down the original section, but there is zero benefit for you. Your boat will sail better and be worth more with a newer section.....cheers
+1 for Ballenger. He made me a some new spreaders and repair plates for my original E27 mast and they fit perfectly. He is very familiar with the E27 spars. Easy to get in contact with too.
Dpig
mherrcat
Sorry if I was incorrect about the manufacturer; my boat is 1985 and it has a Kenyon mast and boom.
BTW, do not order anything from Rig Right if you can avoid it. You will pay 3x the cost and have to put up with people who don't seem to really care about your business. I have talked to Ballenger a couple of times about replacing my boom. As soon as I feel comfortable spending the money (it's only around $1,500 IIRC) that is who I will most likely purchase from.
Alan Gomes
[/COLOR]
As part of the re-rig I just did, I replaced all 6 of the U-bolt attachment points on my E26-2. Rig Rite wanted $215 per U-bolt! I had Garhauer custom make me all 6 for less than the cost of one from Rig Rite. They came out beautiful, by the way.
