Seth,</SPAN>
Thank you for some interesting advice. I have only used the barber with the spinnaker, we never used it like you suggested, but it makes sense. I really hope I will be able to test this.</SPAN>
That was a very good analogy for anyone having trouble visualizing this setup. This is essentially the same thing as "tweakers" or "twings" used to pull down on a spinnaker sheet-only that instead of running a spinnaker sheet though a block which can be pulled down (effectively moving the lead forward), you are running the genoa sheet through the same type of setup...
Keep us posted!
S
