SpudE36RH
Well since it seems we are getting the cruising bug this idea is well received from the provisional Admiral.After doing a 2 niter in summer heat(for Lake Ontario), the ice box with 3 bags didn't make it to the last night really.So whether we are just sitting at home port plugged in full time or away we can enjoy cool foodstuff and beverages. I must say this unit has found Ericson's perfect spot.It was tight getting the jigsaw maneuvered.The space behind was opened up more in the cockpit locker side.There was a basic box for small storage which wasn't a sacrifice.I had to cut out about six inches of poly foam to accommodate the guts of the device behind the scenes.I must say Ericson did a real good job in insulating this Icebox, I'm impressed.Which means max possible poly So great ventilation to the closest cowl.Breathing space for the unit and doesn't encroach much into the cooling space.
So, electrical to run(DC) to own breaker and bolt in place.Dometic NC15, have a wiring graph for length/guage.Cut out was 8 x 12" approximately- shaved here and there to shimmy lower unit parts in.Cruising in 8 days!
John
John
