Dferr
Does anyone know what the psi of the electric fuel pump should or needs to be? I have a Universal 5432. I'm having problems with the engine shutting down when I push the throttle past half. I took the original Facet Pump apart and cleaned it, and now it seems to work perfect. I figured I would just put a new pump in, so I bought another Facet, with a maximum psi of 5.5. When I installed the new one, it did the same as the old pump did prior to cleaning it. I'm thinking it's not enough psi, some other gremlin is haunting me......
Don
Don
