I have a thing against dodgers (Ok, not your problem, I understand that).
HOwever, I also have a thing about rain pouring below even with the main hatch closed unless all four hatch boards are in, as a result of the aft cabin house slanting forward. Which is not a psychiatric problem, is my guess, but a water problem.
Some larger boats I've been on had a rather small companionway dodger which covered only the hatch, leaving uninhibited access to controls and good visibility forward.
I may make one of those to solve the rain problem. It would be designed to be removed and stowed in good weather, rather than folded down. A removable dodger.
Another solution I'm considering is a sheet of clear vinyl which simply covers the area of the hatchboards, and is held in place with Velcro. I had this on a boat long ago, and it was quite good for rain showers or brief squalls. But it was hard to put on from below. You really needed somebody in the cockpit to push the Velcro closed.
And about those four teak hatch boards: there must be a better way?
I've considered a single piece of acrylic. A bit unwieldy but easier to put in and out than hatchboards.
But then, you're hermetically sealed. So it ought to be two piece of acrylic, the top one only maybe four inches, so as to exhaust the scent of wet socks and Dinty Moore.
Ah, but then rains still pours in if you leave the top piece out.
Any better ideas or non-dodger solutions?
