craigtilson
has anyone done a bowsprit and or ran a genaker on a 35-2?
any recommendations
regards craig
any recommendations
regards craig
The 35-2 does very well with A-sails, and while a sprit will be cool, many racers fly them from the spinnaker pole, which has the benefit of being about to be pulled aft for sailing at deeper angles.
If you build and use a sprit, it will be great for closer sailing angles (down to about 120 AWA in lighter air and maybe 150 AWA in bigger breeze) but significantly worse than a sym kite on a pole as the breeze goes aft. The reasons being that a). you won't be able to project the sail in front of the boat with a sprit and b). being a relatively heavy (by todays standards) boat, it does not go much faster on hotter angles than it would with a projected downwind designed spinnaker. Generally speaking not enough faster to make up for the extra distance and extra gybes the way modern sprit boat would, except maybe in very light breezes. If mainly or only cruisng this is not a big deal
This is a bigger dicussion and the answers depend greatly on the type of sailing you are doing. If you can let us know whether you are racing or cruising and some details on the sail inventory I can be more specific. Details please
Cheers
i do both racing and cruising ... many times when i race i am short handed and the winds on the lake are very shifty ... sometimes up to 180 degrees with minimal warning
hence if i use a genaker that may have dual purpose
