I was employed as an energy supply analyst from 1979 through the early 80s. Several things were happening from 1974 to around 82. Oil shock #1 (1974) and #2 (1979), price excursion resulting from unwinding of US oil price controls, hyper inflation touched off by the Viet Nam war. All oil based industries were impacted. Resin, rubber, plastic, fertilizer, etc. became very expensive. Then it was 'discovered' that everything was directly or indirectly made from oil: steel, aluminum, concrete, wood, food, houses, electricity, air travel, war, . . . Retail prices went nuts. Financing rates went truly crazy. Although the resin itself may have been more or less the same (though I am not convinced of that), some - not all - builders cut scantlings and quality control.
Thirty+ years later you can tell if you a hull is bad or not.
So it no longer matters.
