My apologies if all of this has been covered before, but I did search around on the site some, and just wanted to see if I understood this correctly.
Blisters are caused by water seeping--probably from the outside, but maybe influenced by how damp the inside spot it corresponds to is--into the fiberglass laminate layup layers, or however that's said. Once the water gets in there, it forms a bump. There can be a ton of these bumps, large or small, and though they might not sink your boat, they will weaken it over time, probably will grow, make it look bad, and, uh, cause other people to stare and point.
The questions I have are these: 1. Is it pretty well established that salt water creates fewer blisters than fresh water? 2. Is it pretty well established that a boat that has been blister-free in salt water for years may well blister when moved to fresh water? 3. Is it pretty well agreed that a boat that hasn't blistered within a certain number of years from its manufacture date probably won't? If so, how many years would this be? 4. I know that blister problems mostly started being noticed in the 1980s. Is there a "window" to avoid due to blistering problems--especially, of course, for Ericsons? 5. Was there a time--back in the 60's or 70's--when fiberglass boats just didn't blister? If so, does anyone know why? 6. Lastly, are there Ericson models or years or model/year combinations that are well known among cognoscenti (yourselves) as being blister-prone? How about blister-proof?
Tons 'o thanks. Sincerely.
Deadpoet
Deadpoet
