I'll add one more tip about docking short-handed or solo.
When I've singled the Hinckley38 that we used to be partners in, I would always (regardless of crew) rig a short spring line from a large winch about 3/4 of the way aft of the bow, on the side that will be alongside the float/pier/finger, etc. As the boat motors into the slip (angled towards the pier about 10 degrees, then helm swung away from the float to push the stern towards it), the boat is quickly stopped with a burst of reverse, and that single line alone can be dropped over the nearest cleat on the end of the finger, and pulled taut. Then the aux is put in forward idle, and the boat will remain tightly hugging the dock, parallel, with bow and stern under control, while you calmly walk around and fasten your typical set of docklines.
Single-handed, you coil that line on the rail, within reach of the helm position, stop the boat in the slip, and toss a bight over the dock cleat. If the wind's blowing you've only got one shot, so make it good!
Then you can just pull the working end tight, and put a loop around a handy deck cleat, as you shift into forward. In high beam winds, you need to apply a bit more throttle to keep the bow alongsides.
Double-handing, just have your crew stand by the shrouds, holding the dockline, and step off onto the float, and quickly loop that line once around the outer most cleat on the dock, and pull up all slack. This will even serve as an E-brake if you forget to stop the boat with reverse, or if your feathering prop decides not to pop into reverse! :eek:
You may have to experiment with the optimal position of this line. It has to be aft of the widest beam, so that it holds the stern in, but not so far aft that it can't keep the bow alongside the dock when the wind is up.
Sorry for the really long-winded explanation, but I thought this is worth sharing, because a fellow partner on the boat came up with this, and I've been amazed at how easy it makes docking, even alone.
