The Skeleton chronicles
Perhaps it's worth noting that the transition from a FRP interior molding (which saved a ton of production time/money that might have been spent on carpentering up wood settees, hull ceilings, and headliners to...
a
Load-Carrying internal drop-in "frame" was perhaps kind of gradual in the boat building industry.
I personally saw it progress from the lower/settee interior molding of my Ray Richards-designed Ranger 20 (and the R-24 I crewed on) to a more-complete liner/interior in my Hinterhoeller-designed Niagara 26. The later design still had full or partial ply bulkhead pieces heavily glassed to the hull that carried the shroud load via a large size chain plates.
Our 80's Olson 34 actually has a multi-part FRP set of interior moldings that carry the shroud loads after ss rods convey those loads down from the deck "pass through" fittings. This is like the Ericsons of the same era. My interior mold is not a one-piece TAFG, however.
Looking at a King-designed E-boat of the 80's I see the interior TAFG go all the way from bow to stern. This is different than ours, in my mind, because the TAFG has to have its layup varied for each part of the load and geographic position in the boat, and seems to cover the whole inner hull.
I guess that my boat might be called a "partial TAFG" in comparison. In most of my boat, working around the tabbing, I can access the inside hull directly. Owners of TAFG Ericsons are sometimes jealous.
An aside: I spent some difficult hours helping a friend do some plumbing work in the area under his cockpit of a mid-80's Hunter 31. Very similar drop-in interior total-grid system... except that the QC in finishing up where all the hoses and wires go was terrible.
We spent considerable time tidying up sharp edges and straightening out routing of stuff. It was quite an obvious step down in fit and finish compared to the Ericsons I have looked into.
So, to me, the evolution from "furniture" to "load carrying" was where the TAFG really broke from prior production building convention.
Another .02 wasted!
