If you search the archives you'll find a lot about this process.
It is possible to borrow rent or make a bearing press to squeeze the old bearing out of the strut without removing the shaft.
But there are not, as far as I'm aware, two-part marine cutless bearings, so you will have to remove the prop to get the old one off and the new one on, but that is not a big project.
