Hey Brian,
I got your Private Message and responded to it before seeing this post. Hope you don't mind me posting it here (I added some stuff after reading your post here). One other thing, how much clearance do you have with the 13" prop?
Mark
Hi Brian,
I'm using a PakTrakr monitor. It's pretty good but does not really give me the correct state of charge (SOC) readings. The batteries I'm using are AGM's and the AGM setting on the PakTrakr is a bit off from my batteries (reads too low % SOC). If you order a PakTrakr you can have the manufacturer set the SOC 100% - 0% exactly for your batteries. ***(100% -12.9 & 0% 11.8 for your Sea Volt 27's)***
I got the current sensor also, it's great to see the rate of amps going out. You can really save some amp hours by checking the amp usage.
I have a 11x10 fixed prop right now which gives me 4.8 knots at full throttle, the prop is too small, but I knew that going in. I plan on buying a Campbell 12x10 three blade fixed soon.
Not sure about range, I only have 4 - 92 AH batteries and haven't had any issues with running low. I don't motor very far. That said I have 4 - 110AH batteries ordered to add to the mix.
It seems my controller is putting out about 64 amps in full forward and 92 amps in full reverse. Solidnav has a fix for it and will fix it next time they're in town (Santa Cruz CA)***(factory support is fantastic)***. Having a current sensor is a must. I wouldn't have known that I wasn't getting full power in forward without it.
Not sure about regen yet as I have to set up my current sensor differently. With my setup I'm only getting motor draw.
Lots of interesting new stuff this electric propulsion!
All in all I'm happy with the unit and enjoy the tinkering aspect!
How did your existing control cables work for you?
What kind of performance readings are you getting?
Any photos?
Thanks, Mark
