fidji
Eric
I need help to get the replacement fuel filter for my universal M25 I found the right replacement oil filter ( Fram 3593A) but maybe somebody can tell me what is the Fram or Wix model witch can replace the kubota filter or maybe the kubota part number
Thank's:esad::)
Éric
cruis-n
Filter part numbers for M25-XP
I don't know how different the M25 is from the M25-XP so YMMV.
Fuel
Kabota 700043081
Oil
Fram PF57
HTH
Paul
Chris Miller
NAPA's website has a great cross reference section... just type in the number on the current fuel filter and it will find it for you. Keep in mind that only like 3 companies make filters- period. Napa is made by Wix, which are always good.
Chris
rwthomas1
I like Baldwin filters and use them exclusively if they cover my application. I have read enough filter comparisons where they are superior or at least at the top of the heap. They can be hard to find as they are Industrial/Commercial/Fleet products. I do all the maintenance on my vehicles so I just buy bulk. If I can't get a Baldwin then Napa or OEM. Check out www.adiesel.com or www.baldwinfilters.com
RT
ps, yes I'm that lunatic that has 6-12 filters for any vehicle/application on hand....
mherrcat
The Baldwin filters do look good. I'd like to try one. Is there any cross-reference material that matches Baldwin filters to any of the other automotive filters? I'm not sure which one to order. The engine is a Universal M18.
Room?
Probably not a concern for the spin-on fuel filter on the starboard side, but I know that the port side spin-on oil filter for this engine kinda sorta needs to be the smaller stock Universal size to fit in that crowded space with the alternator and the coolant hose, jammed in tight by the block.
My .02 worth,
1988 M25XP
Tom Metzger
M25 filters
The M25 & the M25-XP use the same fuel & lube filters.
Fuel 298854
Lube 300209
These may not be current #s, but will X reference.
fidji
Eric
Thank's to all it's nice to get information when you need it. I'm going with the baldwin filter
Éric
Ericson MK3
Decision:egrin:
Tom Metzger
Universal Filters
I wasn't home when this thread was hot, but I made up a list a while ago with filters for M-25XP & M-25 engines.
<TABLE style="WIDTH: 177pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=235 border=0 x:str><COLGROUP><COL style="WIDTH: 48pt" width=64><COL style="WIDTH: 64pt; mso-width-source: userset; mso-width-alt: 3108" width=85><COL style="WIDTH: 65pt; mso-width-source: userset; mso-width-alt: 3145" width=86><TBODY><TR style="HEIGHT: 18pt" height=24><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 112pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 18pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" width=149 colSpan=2 height=24>Filters and Belts</TD><TD class=xl28 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: #ece9d8; WIDTH: 65pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=86></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl29 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" align=right height=17 x:num="38883">6/15/2006</TD><TD style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD class=xl31 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=2 height=18>Lube Oil Filter</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent">Dimensions</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl33 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Universal</TD><TD class=xl34 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99" x:num>300209</TD><TD class=xl35 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">3 x 3.5L</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17 x:str="Napa ">Napa </TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99" x:num>1334</TD><TD class=xl38 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>21334</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Fram</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99">PH3593A</TD><TD class=xl38 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>STP</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99">S2808</TD><TD class=xl38 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Wix</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99" x:num>51334</TD><TD class=xl38 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Purolator</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99">L14459</TD><TD class=xl38 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD><TD class=xl38 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD class=xl31 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=2 height=18>Fuel Filter</TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent">Dimensions</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl33 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Universal</TD><TD class=xl34 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99" x:num>298854</TD><TD class=xl35 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">2.75 x 2.5L</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17 x:str="Napa ">Napa </TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99" x:num>3390</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Fram</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99">P7514</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Purolator</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99">F50262</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Deutch</TD><TD class=xl39 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">D484</TD><TD class=xl40 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99">FP570F</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Wix</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99" x:num>33390</TD><TD class=xl30 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Hastings</TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99">FF1119</TD><TD class=xl41 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">3 x 2 27/32 L</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl36 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD class=xl37 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: #ffff99"></TD><TD class=xl41 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD class=xl31 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent; mso-ignore: colspan" colSpan=2 height=18></TD><TD class=xl32 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent"></TD></TR></TBODY></TABLE>
fidji
Eric
That's really hot Tom! Thank you, good job . I'm going to print your reply and put it in my maintenance log book:egrin:
Éric
Tom Metzger
Close enuf
Éric - Just bring a Molson or Labatts down to Willsboro. ;)
It wasn't Willsboro, and it wasn't Molson, but it was very good and I enjoyed getting together with you.
Thanks again.
The Pic is Éric anchored at Quaker Smith.
Steve
Oil Filter - Metric vs Imperial
-We just searched into this thread for the handy cross reference chart for my fuel filter to go from the Universal #298854 to NAPA #3390, to save a few $ working outside of classic marine up-marketing.
However I noticed an omission in oil filter sizes that needs noting. Apparently many, if not all M-30 and 5424 (& others?) where fitted with imperial NF 3/4" thread, Universal #299927. An unfortunate coincidence is the adapters with 20 mm x 1.5 metric threads (#300209 NAPA 1334) and 3/4" NF (16 tpi) imperial threads are so similar in size that an oil filter with the 20 mm x 1.5 metric threads will screw onto an adapter with 3/4" NF threads. The risk is the 20 mm filter could blow off the 3/4" adapter under severe conditions. Our 5424 takes a NAPA #1342 3/4" NF, it is also not possible for a 3/4" NF thread filter to fit onto an 20 mm adapter, so your safe in one direction but not the other.
Steve E35-3 #159
Tom Metzger
Corrected filter numbers
Thanx to Steve I just checked the filter numbers on the Torresen Marine site and found the M-20 & M-30 lube oil filters were wrong and/or out of date.
As a point of interest, it took me 15 minutes to correct the info and an hour and a half to figure out how to copy the table to this page. A real PITA.
<O:p</O:p
The correct info:
<TABLE style="WIDTH: 192pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=256 border=0 x:str><COLGROUP><COL style="WIDTH: 48pt" span=4 width=64><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" width=64 height=18></TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=64></TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=64>Lube Oil</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 48pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=64>Fuel</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18></TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent"></TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Filter</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent">Filter</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M2-12</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-12</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-15</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>5411</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>299381</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-18</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M3-20</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-20</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>5416</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num><FORM action=https://shop.torresen.com/cart/proc/_cart.php method=get>299381 </FORM>
</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-25</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>5421</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-25XP</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M4-30</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-30</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>5424</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num><FORM action=https://shop.torresen.com/cart/proc/_cart.php method=get>299381 </FORM>
</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-35</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>300209</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-40</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">-</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>299927</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD class=xl26 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; HEIGHT: 13.2pt; BACKGROUND-COLOR: transparent" height=18>M-50</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>5444</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>299927</TD><TD class=xl25 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" x:num>298854</TD></TR></TBODY></TABLE>
Chris A.
M-25 table
So Tom, just to verify, your original table (which I refer to frequently- thank you!) has correct filter numbers for the M-25 and M-25XP. The issue sounds like a different oil filter thread on some other engine models.
Correct?
Tom Metzger
M-25 & M-25XP are OK
Chris - Yes, the Universal M-25 numbers and my cross references are correct and my son who has an M-25 and I with an M-25XP have been using them for years.
Only the M-30 was wrong. The M-20 was out of date.
This does show the importance of double checking info from the web.
