Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Fuel filter
  1. #1
    Eric
    Join Date
    Mar 2007
    Location
    west chazy N.Y.
    Posts
    49
    Fuel filter
    I need help to get the replacement fuel filter for my universal M25 I found the right replacement oil filter ( Fram 3593A) but maybe somebody can tell me what is the Fram or Wix model witch can replace the kubota filter or maybe the kubota part number
    Thank's
    Éric
  2. #2
    Sustaining Member cruis-n's Avatar
    Join Date
    Jan 2003
    Location
    North TX
    Posts
    85
    Filter part numbers for M25-XP
    I don't know how different the M25 is from the M25-XP so YMMV.
    Fuel
    Kabota 700043081
    Oil
    Fram PF57
    HTH
    Paul
  3. #3
    Principal Partner mherrcat's Avatar
    Join Date
    Dec 2007
    Location
    Channel Islands Harbor, Oxnard CA
    Posts
    1,481
    I'm a little leery of Fram filters. Here is some info on engine oil and filters I found when doing research for my motorcycle. Some of it was done specifically for motorcycle applications, but some of the general filter construction info is still relevant.
    http://motorcycleinfo.calsci.com/Oils1.html
    http://www.knizefamily.net/minimopar/oilfilters/index.html
  4. #4
    Principal Partner Chris Miller's Avatar
    Join Date
    Feb 2005
    Location
    Saint Leonard, Md
    Posts
    686
    NAPA's website has a great cross reference section... just type in the number on the current fuel filter and it will find it for you. Keep in mind that only like 3 companies make filters- period. Napa is made by Wix, which are always good.
    Chris
    Chris Miller :cartmann:
    S/V [I]Sequoia[/I]
    1988 38-200 Hull #262
    [URL="http://svsequoia.blogspot.com/"]http://svsequoia.blogspot.com/[/URL]
  5. #5
    Principal Partner
    Join Date
    Jan 2006
    Location
    Wakefield, RI
    Posts
    1,701
    I like Baldwin filters and use them exclusively if they cover my application. I have read enough filter comparisons where they are superior or at least at the top of the heap. They can be hard to find as they are Industrial/Commercial/Fleet products. I do all the maintenance on my vehicles so I just buy bulk. If I can't get a Baldwin then Napa or OEM. Check out www.adiesel.com or www.baldwinfilters.com
    RT
    ps, yes I'm that lunatic that has 6-12 filters for any vehicle/application on hand....
    Rob Thomas
    Wakefield, RI
    1983 Ericson E38 "Ruby"
    "I purchased a boat because setting fire to $100 bills was not an efficient enough way to dispose of them...."
  6. #6
    Join Date
    Dec 2007
    Location
    Posts
    1,481
    The Baldwin filters do look good. I'd like to try one. Is there any cross-reference material that matches Baldwin filters to any of the other automotive filters? I'm not sure which one to order. The engine is a Universal M18.
  7. #7
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,510
    Blog Entries
    63
    Room?
    Probably not a concern for the spin-on fuel filter on the starboard side, but I know that the port side spin-on oil filter for this engine kinda sorta needs to be the smaller stock Universal size to fit in that crowded space with the alternator and the coolant hose, jammed in tight by the block.
    My .02 worth,
    1988 M25XP
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  8. #8
    Principal Partner Tom Metzger's Avatar
    Join Date
    Oct 2002
    Location
    Clifton Park, NY
    Posts
    1,513
    M25 filters
    The M25 & the M25-XP use the same fuel & lube filters.
    Fuel 298854
    Lube 300209
    These may not be current #s, but will X reference.
    Tom Metzger
    E-34 Xanthus
  9. #9
    Principal Partner
    Join Date
    Dec 2004
    Location
    Annapolis, MD
    Posts
    1,294
    OEM Universal filters from Torrenson Marina at diesel direct dot com.
  10. #10
    Eric
    Join Date
    Mar 2007
    Location
    west chazy N.Y.
    Posts
    49
    fuel filter
    Thank's to all it's nice to get information when you need it. I'm going with the baldwin filter
    Éric
    Ericson MK3
    Decision
  11. #11
    Join Date
    Oct 2002
    Location
    Clifton Park, NY
    Posts
    1,513
    Universal Filters
    I wasn't home when this thread was hot, but I made up a list a while ago with filters for M-25XP & M-25 engines.
    Filters and Belts
    6/15/2006
    Lube Oil FilterDimensions
    Universal3002093 x 3.5L
    Napa 133421334
    FramPH3593A
    STPS2808
    Wix51334
    PurolatorL14459
    Fuel FilterDimensions
    Universal2988542.75 x 2.5L
    Napa 3390
    FramP7514
    PurolatorF50262
    DeutchD484FP570F
    Wix33390
    HastingsFF11193 x 2 27/32 L
    Tom Metzger
    E-34 Xanthus
  12. #12
    Eric
    Join Date
    Mar 2007
    Location
    west chazy N.Y.
    Posts
    49
    Wink Fuel filter
    That's really hot Tom! Thank you, good job . I'm going to print your reply and put it in my maintenance log book
    Éric
  13. #13
    Join Date
    Oct 2002
    Location
    Clifton Park, NY
    Posts
    1,513
    Éric - Just bring a Molson or Labatts down to Willsboro.
    Tom Metzger
    E-34 Xanthus
  14. #14
    Join Date
    Oct 2002
    Location
    Clifton Park, NY
    Posts
    1,513
    Smile Close enuf
    Quote Originally Posted by Tom Metzger View Post
    It wasn't Willsboro, and it wasn't Molson, but it was very good and I enjoyed getting together with you.
    Thanks again.
    The Pic is Éric anchored at Quaker Smith.
    Attached Images Attached Images
    Tom Metzger
    E-34 Xanthus
  15. #15
    Sustaining Partner Steve's Avatar
    Join Date
    May 2002
    Location
    New Hampshire
    Posts
    232
    Oil Filter - Metric vs Imperial
    -We just searched into this thread for the handy cross reference chart for my fuel filter to go from the Universal #298854 to NAPA #3390, to save a few $ working outside of classic marine up-marketing.
    However I noticed an omission in oil filter sizes that needs noting. Apparently many, if not all M-30 and 5424 (& others?) where fitted with imperial NF 3/4" thread, Universal #299927. An unfortunate coincidence is the adapters with 20 mm x 1.5 metric threads (#300209 NAPA 1334) and 3/4" NF (16 tpi) imperial threads are so similar in size that an oil filter with the 20 mm x 1.5 metric threads will screw onto an adapter with 3/4" NF threads. The risk is the 20 mm filter could blow off the 3/4" adapter under severe conditions. Our 5424 takes a NAPA #1342 3/4" NF, it is also not possible for a 3/4" NF thread filter to fit onto an 20 mm adapter, so your safe in one direction but not the other.
    Steve E35-3 #159
  16. 11-06-2008, 08:43 PM
Similar Threads
  1. Universal 25 Air Filter
    By Ed Balun in forum Maintenance & Mechanical
    Last Post: 01-13-2008, 08:05 PM
  2. Oil viscosity and filter
    By Kim Schoedel in forum Maintenance & Mechanical
    Last Post: 10-30-2007, 08:06 PM
  3. Oil Residue at air filter
    By ted_reshetiloff in forum Maintenance & Mechanical
    Last Post: 07-28-2006, 11:50 PM
  4. Fuel lift pump Vs Primary fuel filter height
    By CaptnNero in forum Maintenance & Mechanical
    Last Post: 05-30-2006, 08:24 AM
  5. air filter for Universal M-40?
    By mark reed in forum Maintenance & Mechanical
    Last Post: 02-11-2005, 05:37 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
