FWIW, here is how my system is wired up:
Battery bank #1 = (3) group 31 wet cells all paralleled together
Battery bank #2 = (1) group 31 dedicated starting battery
Standard 1, 2, 1+2 and Off battery switch, banks wired as numbered
Xantrex 20amp AC battery charger
Stock alternator on Universal 5432 engine.
The Xantrex charger has TWO charge leads so it automatically charges both banks when it is turned on, regardless of battery selector switch position.
I never use the start battery for anything but emergency starting. Occasionally I switch the selector switch to "both" when running the engine to top off the start battery. This is rare as I use a Honda 2000watt portable generator to recharge my batteries when I need it. I hate running the engine, the boat is on a mooring and I motor infrequently so engine charging with a stock alternator/regulator is a waste of time.
My AB refigeration system sucks the juice down quite quickly, something like 5amps per hour? The insulation in the icebox sucks too. The Honda has to run every day to keep up even out for a weekend. This is not so bad as the Honda is VERY quiet and I try to run it either in the early evening during peak electrical use or while I am off the boat for a few hours, etc. Even if I don't charge while out for a weekend then I need to leave the Honda running for a long while once back on the mooring. Some may be uncomfortable leaving a running generator on the deck but it has not been an issue and I don't see why it would.
My solution is multi-pronged:
-Increasing house battery bank to 460Amp/hr. of 6volt golf cart batteries.
-Installing Ample Power alternator/regulator (in basement now)
-Installing Xantrex 2000watt inverter w/100amp charger integral
-Installing Link 20 or 2000.
-Tearing out icebox this winter to install new, thicker insulation and Glacier Bay icebox lid.
Solar panels and/or wind generator are distant future possiblities.
There are a couple of things going on here. The poorly insulated icebox is a power hog. The quickest and easiest fix is more/better isulation and a really good lid. This will help more than anything. The second issue is charging the batteries.
The trouble with battery chargers is they often don't deliver the amps needed to truely recharge batteries quickly during the "bulk" charge phase. AFAIK, when charging a battery from the 50% discharge state to 80% charged, the bulk phase, this is the stage when the battery will accept the most energy in the shortest period of time. It makes sense to utilze a charger that can deliver lots of energy. The Xantrex inverter/charger has a 100amp charger built in. This will charge my batteries much faster during the bulk phase than the 20amp unit currently installed. The added benefit is AC power when I want it and automatic switching from inverter AC and dockside AC.
The upgraded Ample Power alternator/regulator will also help. Although I don't run the engine all that much the upgraded units will perform far better than my stock setup. At least when I do run the engine there will be serious output from the alternator and far better charge control with the new regulator.
Whats this all mean? At the end of it the system will be able to run for longer before needing recharging and the recharging will be faster and more efficient.
The way I see it this will make the boat more comfortable, useable and safer. Safer you say? Hows that? More Amp/hrs means that in nasty weather the radar, autopilot, gps, nav lights, etc. will last longer. This is really nice if for some reason the engine quits.....
Are all these things needed? Depends on what you want to do. Honestly, if I was jkm and just needed to keep beer cool I would look seriously into reworking the icebox or simply using ice. I "jumpstart" my refrigeration system with 3 blocks and 2 bags of ice every weekend trip. They are usually only 50% gone after two days. Ice is pretty cheap compared to all the crap I am working towards. To each his own. I just wanted to show where I was coming from when I make recommendations on this kind of topic. RT
