Results 1 to 5 of 5
Thread: Refrigeration
  1. #1
    Principal Partner
    Join Date
    Dec 2005
    Location
    Chattaroy, WA
    Posts
    373
    Refrigeration
    Time to convert the big ice box! Our 1984 35-3 is already originally pre-wired. Looks like I have a couple of choices that make sense. The Nova Cool comes with a small Evaporator/freezer box that may fit in the ice box, the overflow cool thus refers the whole ice box. Other choice is the Frigaboat unit that has a flat evaporator that I can leave flat or have the supplier bend it to an L or U shape.
    In hopes that someone out there in Ericson land has been there-done that.
    I presume, part of this upgrade will be to replace the old 20 amp charger with a new smarter charger so we can leave stuff in the frig when hooked up to shore power. Any thoughts? Thanks,
    Kim
    Windfall
    1984 35-3
  2. #2
    Moderator Guy Stevens's Avatar
    Join Date
    Apr 2005
    Location
    San Fran Area
    Posts
    1,027
    Blog Entries
    1
    SeaFreeze Bellingham Washington
    SeaFreeze in Bellingham Washington, makes a great off the shelf unit, customized to you box sepcification for less than either of the options that you have listed.
    Call them and have them custom bend it to fit your box, get it, wire it up, and connect the evaporator plate, and be done with it.
    I have installed a number of thier units in a number of boats, and always have been pleased, as have the customers.
    Guy
  3. #3
    Principal Partner
    Join Date
    Dec 2004
    Location
    Oceanside, CA
    Posts
    375
    Norcold Auto 12V/120V
    Installed the Norcold SCQT for the Ice Box Conversion on the
    E35-II. The Ice Box is close to 6CF and this rig works great
    here in SoCal without any insulation mods. The install was super
    easy and I located the Compressor in the Starboard Cockpit Locker.
    Bought it used, installed the Evaporator and Compressor and had
    a Refrigeration Tech charge er up. Freezes water on the bottom
    on the lowest setting. Might even freeze your favorite beverage
    on the medium setting. Runs quiet and never complains
    The cool thing is that it comes with its own tranformer/controls
    and runs a 12V Compressor on 12V/120 automatically. Even shuts
    off when 12V drops low....so you don't lose your batteries :eek:
    Draws 3-5A @ 12V. With a 50% duty cycle thats 60AH/Day max.
    Most Pirates freeze water jugs prior to trips to help with the
    refrigeration load on the batteries.
    As you look at other models you will find that all the controls and
    power conversion options are expensive OPTIONS on most conversion
    kits. I have found that this installation has improved my attitude
    about projects and not having to haul ice and beverages around
    all the time
    Happy Cold Beverages /) /)
    Dan Simpson
    s/v Merlin
    74' E35-II #382
    Oceanside Harbor, CA
  4. #4
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,605
    Blog Entries
    63
    Thumbs up Keeping Cool
    For info on refrigeration installs on other Ericsons and Olsons, use the Search function, upper right on this page.
    I put in some info on our Frigoboat installation at one of the many threads that will come up with a search on Frigoboat, just as a for-instance.
    Here is the thread URL --
    http://www.ericsonyachts.org/infoexc...&referrerid=28
    We still like ours a lot and have had no problems with it. If you need some better photos of the installation, let me know...
    I found this one of the compressor, looking in under the galley module. The compressor is mounted on two bent alum. brackets. The wood plug sitting there is actually tethered to the thruhull, just out of the picture on lower right (where that blue sink drain hose is going. If it looks crowded, that's because it is.
    And here is a photo of the area just to the lower right of the compressor, showing the galley sink thru-hull, with the Keelcooler almost out of sight behind it, and the edge of the compressor in view on the left. Above both of these is the shelf where the pans are stored and just above that is the double sink. I could, of course, do this install much faster on another Olson, but only for a very good friend!
    Olson 34 Fresh Air
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1116   Click image for larger version.
  5. #5
    Principal Partner
    Join Date
    Dec 2005
    Location
    Chattaroy, WA
    Posts
    373
    Thanks everyone for your input. I will march on towards the constant cooling of the grog!!
    Kim
    Windfall
    1984 35-3
Similar Threads
  1. E-35 III refrigeration replacement/upgrade
    By jim kizziar in forum Maintenance & Mechanical
    Last Post: 07-24-2005, 01:15 PM
  2. Installing Refrigeration on my 27
    By Jet Stream in forum Maintenance & Mechanical
    Last Post: 05-30-2005, 10:00 PM
  3. Ericson 38-200 Refrigeration
    By oceandreams89 in forum Maintenance & Mechanical
    Last Post: 06-01-2004, 07:12 PM
  4. E 36C Refrigeration
    By OliveOyle in forum Maintenance & Mechanical
    Last Post: 12-24-2003, 04:59 PM
  5. 35-3 Refrigeration & the better half
    By Steve in forum Maintenance & Mechanical
    Last Post: 05-20-2002, 09:40 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
