For Sale 1988 32-200
Status
Not open for further replies.
saildog
Our boat is a 1988 32-200 that has been extensively upgraded and meticulously maintained. New main, mylar 150, radar, auto pilot, GPS, stereo, 6 disc CD changer, varnished teak interior, new dodger, spinnaker in a sock, custom radar mount on stern with outboard hoist and spotlight. Much more, too much to list, contact me for more information at acpd32@comcast.net. $53,900. Boat is in Rhode Island under her Fairclough winter cover.
Sven
Seglare
Do you have any pictures and an inventory list you could post ?
Why are you selling ? :-(
-Sven
saildog
Luna
Ericson 32-200 Series (Aft Cabin Layout)
1988
HIN #ERY32804H788 White Hull, Tan decks, Double Navy Boot and Shear Stripe
LOA 32’ 6” I = 42.0’
LWL 25’ 10” J = 13.75’
BEAM 10’ 10” P = 36.0’
DRAFT 6’ 1” E = 11.5’
DISP 9800 lbs
BALLAST 4200 lbs
D/L RATIO 260
POWER TO WEIGHT 17.32
SCREEN VALUE 2.04
SAIL AREA 496 sq.ft. (Main = 207 sq. ft. / 100% Triangle = 289 sq. ft.)
Rig: Sloop (Double Spreader Rig)
Designer: Bruce King
Vessel is Documented
Bottom was factory epoxy barrier coated (ISO NPG Gelcoat)
Engine: Universal Diesel 3 cyl 23 hp FWC Model XP25
Hours =
22 Gal. Fuel Tank
Sails: 2/2 Battened Pentax Tri-radial Main, 2 Reef Points, Banks 2003, Excellent Condition
150% Genoa, Mylar with foam luff pad, Thurston 1996, Excellent Condition
110% Genoa Roller Reef with Blue Acrylic Cover, Thurston 1988, Excellent Cond
135% Bi Radial Genoa with foam luff pad, Thurston 1991, Fair Cond
Cruising Spinnaker multi-color with sock, Moorehouse Sails 1986, Very Good Cond
Storm Jib
PHRF rating 184 non-spinnaker; boat points very well
This Ericson is in excellent condition inside and out and has been meticulously maintained by its owners. She accommodates 2 couples in 2 private staterooms with a comfortable port and starboard settee between them. The galley is to port with deep double stainless steel sinks and 2 burner stove & oven and a Nav area to starboard with large ice box under.
Canvas:
• Fairclough winter cover, 1998
• New Dodger (2003) with Awning & Pole, Winch Covers, Wheel Cover, Compass Binnacle Cover, Instrument Covers. All in Navy Blue.
• Custom Navy Sail Cover with 2 Red Stripes, 2003
Instruments:
• B&G Hector and Hornet s ailing monitors 1988, with 2 sets of repeaters, one on port side of cockpit and the other at the helm on Edson custom pods with teak backs. Repeaters and pods 1992
• Standard Horizon VHF, cockpit speaker
• Furuno Model 1621 Radar, swings into companionway on special bracket, 1994
• Auto Pilot ST4000 with remote, 1994
• Radar mounted on custom Edson tower. Tower completely removable in the event of a hurricane, mounted on the stern transom on Edson pivot bracket.
• Magellan GPS at Nav Station, 1994
• Stereo/cassette with 4 speakers, 2 in main cabin and 2 in cockpit. 6 disc CD changer
• All instruments have rigid face covers in addition to canvas
• Quick Vang, 1996
Miscellaneous:
• Complete interior varnished
• Automatic water sensing bilge switch
• Hot & cold pressure water with large head & shower, external dockside water connection
• Manual salt & fresh water footpumps as well
• 110 vac dockside power with 50’ 30 amp cord
• 59 gals water, 23 aft, 30 port, 6 hot water tank
• Lewco 20 amp battery charger
• Harken roller furling
• 2 - 110 vac brass lamps with shades, 1 aft, 1 vee berth
• 4 closed cell cockpit cushions, beige
• Cunningham 6:1 purchase
• Forespar reaching pole, line control type, mast mounted on long track and car with topping lift, 1991
• Edson steering with 54” guard, brake, 36” buckskin covered wheel
• Ritchie SP-5 with cover and light
• Batteries – 2 Trojan Grp 31, 1 Grp 27
• CQR 25lb anchor with 250’ ½” nylon rode & 15’ 3/8” chain
• Custom upgraded interior cushions, new foam 2002
• 7 Lewmar opening ports with screens, 3 in aft cabin, 2 forward, 1 port atf, 1 stb head
• 2 Lewmar rollstop hatches with custom screens, new lens 2003
• Custom main companionway screen with zippered entrance
• Mast mounted deck light
• Firdell radar reflector mounted on mast, 1994
• New prop shaft, cutlass & prop balance 2003
• White horseshoe buoy with holder and line to MOB pole & flag
• Fireboy automatic halon 1301 fire suppression system
• Double SS deep sinks
• Nav station with large ice box below
• Double boot stripe navy blue (gel coat, not paint)
• Double shear stripe navy blue (gel coat, not paint)
• CNG stove/oven with tank & regulator, 2 tanks
• 2 bilge pumps automatic (water sensing switch)
• Manual bilge pump
• Swim ladder
• 2 cowl vents aft
• Inclinometer
• 2 PVC winch holders in cockpit
• Double life lines with 2 boarding gates
• 2 solid brass Frigast Danish bulkhead lights
• 1 solid brass Frigast Danish navigation table light
• 1 solid brass lantern (small) on bulkhead)
• 2-blade solid brass feathering max prop, 1995
• Edson hoist mounted on radar tower (for lifting outboard engine), 1997
• Original Ericson manuals
Winches:
• 2 Barrient #24 self-tailing, 2 speed
• 1 Barrient #18
• 3 Barrient #10
• 2 winch handles
Coast Guard Equipment:
• Flare kit custom-mounted inside stern lazarette lid
• Air horn
• 2 ABC extinguishers
Following Lines Led Aft:
• Main halyard, genoa halyard, spinnaker halyard (spare) – all new in 2001, 1st & 2nd main reef lines, main sheet, boom vang, traveler.
• New jib sheets 2003
Custom Woodwork:
• Complete interior varnished, custom teak shower grate, custom magazine rack, custom pinrail in vee berth & aft berth, custom louvered doors on port & stb vee berth for easy access, 2 additional grab handles at v-berth entrance, custom TV table in aft quarters, custom fold down teak tray table
Offered at: Vessel location: East Greenwich, RI
Last Survey: 1998
Contact: Alan Desrosiers
Home 413-967-5526
Work 508-795-0110 x204
Cell 508-958-7070
Sven
Seglare
A beautiful picture of a beautiful boat:
Status
