supersailor
Thanks Frank. Loren did a check with an infared temperature sensor on his trailer plugs and found a large temperature gain at the trailer plugs. Somehow that necessary replacement morphed into a complete engine replacement. You gotta watch these repairs morphing into monsters. A new Beta sure sounds neat, though!
A check like Loren's will tell you if the plugs still are ok. If you have the time, replacement is a good idea.
The side panel removes on the 34. The starter is easy to remove. A flex drive on a socket might work to remove the bolts. Try soaking the bolts with PB Blaster for a couple of days prior to the removal.
