Results 1 to 12 of 12
Thread: Forespar steaming/deck light led replacement
  1. #1
    Principal Partner Mark F's Avatar
    Join Date
    Sep 2003
    Location
    Felton CA
    Posts
    985
    Blog Entries
    5
    Has anyone replaced the bulbs on a Forespar steaming/deck light fixture with LED's? I'm trying to find LED replacements and having a hard time finding the top (steaming) light.
    Lotus Flower
    1976 E27
    Electric Inboard
    Santa Cruz CA
  2. #2
    Join Date
    Apr 2006
    Location
    Nanaimo, British Columbia, Canada on Vancouver Island
    Posts
    1,944
    Hi Mark,
    While I understand replacing bulbs with LED in high use areas, like salon, anchor light, the steaming light is mainly used while motoring at night, so the alternator would easily replace any battery amps used for the streaming light. Just puzzled why you feel the need for that change.
    Principal Partner gadangit's Avatar
    Join Date
    Jan 2012
    Location
    San Leon, TX
    Posts
    300
    Blog Entries
    3
    Hi Mark-
    I am pretty sure I replaced the steaming light with a festoon LED lamp. The replacement was not a coast guard certified (or whatever that would be) lamp, but has worked just fine and bright for a few years with lots of night use. Let me do some research in the morning to see what I did.
    All those little loads add up!
    Chris
    Chris and Lisa
    1972 Hull #53 Ericson 39 "SolAire"
    San Leon, TX
  4. #4
    Join Date
    Jan 2012
    Location
    San Leon, TX
    Posts
    300
    Blog Entries
    3
    Quote Originally Posted by Frank Langer View Post
    Hi Frank-
    Speaking for Mark, he has an electric motor for propulsion and at night will be completely on battery. No solar to help, every little load reduction makes a difference.
    Chris
    Chris and Lisa
    San Leon, TX
  5. #5
    Join Date
    Sep 2003
    Location
    Felton CA
    Posts
    985
    Blog Entries
    5
    Hi Frank,
    Chris is right - electric drive so no alternator. Additionally I want to replace the anchor light. The current bulb for the anchor light is 10 watts @12 volts festoon (with indentations on the ends) 1 3/4" long.
    Thanks for checking Chris.
    Lotus Flower
    1976 E27
    Electric Inboard
    Santa Cruz CA
  6. #6
    Join Date
    Jan 2012
    Location
    San Leon, TX
    Posts
    300
    Blog Entries
    3
    Assuming you have the ML-2, Defender sells the Forespar LED replacement for the steaming part of the fixture. It is pricey. I can't find my original order, but I think I spent some time researching this and purchased an identically spec'd "off brand" festoon LED lamp for just a few bucks.
    Forespar PN 132325
    For the anchor light I got one with a photocell that turns it off automatically. I am certain this has saved me countless hours of sailing around with my anchor light on.
    Chris
    Chris and Lisa
    San Leon, TX
  7. #7
    Join Date
    Sep 2003
    Location
    Felton CA
    Posts
    985
    Blog Entries
    5
    Thanks Chris. So the steaming light replacement is a 360 deg. projection "bulb" and limited to 225 deg. by the light housing/mast. Now I get it.
    Lotus Flower
    1976 E27
    Electric Inboard
    Santa Cruz CA
  8. #8
    Join Date
    Oct 2015
    Location
    Seattle, WA
    Posts
    180
    What do you need a steaming light for??? Your E27 has to be the best sailor of all the 27ís
    -P
  9. #9
    Contributing Member II
    Join Date
    Oct 2012
    Location
    Rocky River, Ohio
    Posts
    39
    Have you tried Marinebeam. They have a chart where you can pretty much match your bulb to pictures on the chart.
    Then call them to confirm. They have always been very helpful and I have been happy with their lights. I have replaced all
    of the bulbs and/or fixtures on our current E32-3 as well as our former boat, an E27, which also was electric powered BTW.
    Bob
    Bob G
    1985 E32-3 #650
    Universal M25
    Celerity
    Sailing on Lake Erie
  10. #10
    Advanced Beginner bgary's Avatar
    Join Date
    Aug 2015
    Location
    Everett, WA
    Posts
    1,305
    Blog Entries
    23
    +1 on MarineBeam.
    Not only are they great to work with, their LEDs have some sort of magic built into them (voltage regulator circuitry?) that allows them to work across voltage variations.
    Some of the cheaper LEDs *only* work at 12V, and if the voltage drops below a certain value (I've heard 11.6V) the LED doesn't light up.
    $.02
    Bruce
    "Makana" (ex-Thelonious)
    1985 Ericson 32-III #604
    Makana blog: here
  11. #11
    Join Date
    Feb 2016
    Location
    Houston, TX
    Posts
    75
    Blog Entries
    1
    Another vote for Marinebeam. Well made and reasonably priced, at least compared to other brand names. I replaced all lights, internal and external with their units.
    Another thing to consider is a retrofit LED bulb vs. a new sealed LED unit. Retrofit will be significantly less expensive, less work and may or may not satisfy USCG regulations. Sealed unit costs more but prevents bulb/receptacle corrosion and is USCG certified. Just look inside any old navigation light. I am really surprised they work at all.
    Still Crazy, E32-3, 1987
  12. #12
    Join Date
    Sep 2003
    Location
    Felton CA
    Posts
    985
    Blog Entries
    5
    Thanks Everyone.
    It's kind of fun that there are multiple EP folks on this thread. SolAire, Cinderella, Lotus Flower and Celerity's older sister ;-)
    BTW, Pajo, how about an update?
    Lotus Flower
    1976 E27
    Electric Inboard
    Santa Cruz CA
Similar Threads
  1. Replies: 6
    Last Post: 08-15-2018, 07:58 AM
  2. Forespar Bowlight and Foredeck Light
    By gulfcoaster in forum Maintenance & Mechanical
    Last Post: 09-07-2011, 02:41 PM
  3. 34-200 Deck Light
    By 1beardsley in forum Maintenance & Mechanical
    Last Post: 09-28-2010, 08:49 PM
  4. Steaming light bulb--1984 Ericson 30+
    By Frank Langer in forum Maintenance & Mechanical
    Last Post: 04-09-2008, 12:21 PM
  5. Steaming/Anchor light
    By Jerry in forum Maintenance & Mechanical
    Last Post: 11-26-2007, 11:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
