Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: cockpit drain E35-2
  1. #1
    Principal Partner steven's Avatar
    Join Date
    Oct 2005
    Location
    Annapolis
    Posts
    372
    cockpit drain E35-2
    I am again looking at feasibility of gravity drain of the aft cockpit that would exit above the waterline for use while in port.
    That way I can close the scupper seacocks (which drain below the waterline) when the boat is left unattended.
    Looks like there is enough fall to exit at the very bottom of the transom. But it looks close.
    Might instead have to go beneath the stern counter, exiting though the bottom overhang above the water line.
    Has anyone done this ?
    thanks
    --Steve
    Steve and Paula
    Indigo E35-2 #446
    Annapolis
  2. #2
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,089
    Blog Entries
    78
    That's the way the mid-80s boats do it for the outer scuppers.
    Name:  2-E32-3 cockpit drains.JPG
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  3. #3
    Join Date
    Oct 2015
    Location
    Georgian Bay, Ontario
    Posts
    168
    "That way I can close the scupper seacocks"
    Dealing with drains and seacocks on my 35-2 is on my list, I really do not like leaving seacocks open when I am away from the boat. But what about draining the main cockpit area..? if you close the seacocks off and get a lot of rain, it will back up into the cockpit quickly and get ugly.
    I am planning a T just below the main cockpit drains with a 3/4 hose back to an exit in the transom above the waterline to take care of rain water accumulation (and T'd with aft cockpit drains)
    1978 35-2, Atomic 4
    Crystal Current
  4. #4
    Join Date
    Oct 2005
    Location
    Annapolis
    Posts
    372
    yes I have essentially the same plan.
    Am also considering cutting a limber hole from the main cockpit to the skippers well so they both will drain.
    but re "T just below the main cockpit drains with a 3/4 hose back to an exit in the transom above the waterline"
    Do you think there enough of a drop to do this ?
    --Steve
    Steve and Paula
    Indigo E35-2 #446
    Annapolis
  5. #5
    Join Date
    Oct 2015
    Location
    Posts
    168
    I have not got into the project but just visually it looks like there should be enough drop. Does not need much and not talking about a lot of water.
    I don't think the limber hole plan would work unless you glass in a tube joining the two cockpit wells underneath the bridgedeck (if that is the right term...)
    1978 35-2, Atomic 4
    Crystal Current
  6. #6
    Join Date
    Oct 2015
    Location
    Posts
    168
    also, the main cockpit slopes forward to drain so a lot of water would need to accumulate before it would drain aft... and it would not drain the forward portion ever
    1978 35-2, Atomic 4
    Crystal Current
  7. #7
    Contributing Member II
    Join Date
    Dec 2018
    Location
    Berkeley, CA
    Posts
    34
    If you make sure the valves are good and hoses are good and secure and there's no way it's going down while at the dock... Agree the limber hole is bad idea, just tee the hoses... or maybe find another project that is also a safety item, like how is the bilge pump situation?
    1970 35-2 Hull 154, formerly 'Virgo'
  8. #8
    Join Date
    Oct 2015
    Location
    Posts
    168
    of course the bilge pump should be in good working order (I have yet to tackle this as there is nowhere obvious to put it and no access on the 35-2)
    But it is just good form to shut off all seacocks when leaving the boat. If they are never ever shut off, as is the case with most 35-2'... why have seacocks at all? just pipe straight to a thruhull barb... one less fitting and one less source of leaking. Most will be frozen up due to lack of use.
    1978 35-2, Atomic 4
    Crystal Current
  9. #9
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,089
    Blog Entries
    78
    Primarily, so that plumbing can be accessed, worked on, removed or replaced.
    The notion that they are there to save you, and that open seacocks are unsafe, and that they must be closed every time you leave the boat, is an interpretation.
  10. #10
    Join Date
    Oct 2015
    Location
    Posts
    168
    "Primarily, so that plumbing can be accessed, worked on, removed or replaced."
    yes this of course... agreed. The above was an oversimplification. But most plumbing repairs etc are done between seasons and at haulouts and most by far of these seacocks are never exercised and likely will not move when needed.
    This is very much a 'your boat your choice' kind of thing, but on mine I am not comfortable at all leaving seacocks open when I am away from the boat and will reroute the drains so I am able to close them.
    1978 35-2, Atomic 4
    Crystal Current
  11. #11
    Join Date
    Oct 2005
    Location
    Annapolis
    Posts
    372
    I am particularly concerned that about leaving seacocks open in freezing winter.
    Steve and Paula
    Indigo E35-2 #446
    Annapolis
  12. #12
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,605
    Blog Entries
    63
    Lightbulb
    Quote Originally Posted by steven View Post
    Frozen hose and thru hull and then a split in the hose.
    That's what almost 90% sunk a sailboat in our moorage a couple of years ago. I used the club's gas-powered portable pump until a company with multiple large pumps could get there. Close call.
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  13. #13
    Join Date
    Oct 2005
    Location
    Annapolis
    Posts
    372
    right !
    I currently close the thruhulls, fill the hoses with antifreeze, and stopper the scuppers .
    So the cockpit becomes a bathtub. To drain the cockpit I have 12v bilge pumps on a float switches temp wired to the house battery. A kluge, but it works as long as the ships batteries stay charged, and debris doesn't foul the pump, and the float switch doesn't stick open or closed (for example, with ice).
    A gravity drain for use only in port in winter would be much better I think.
    Steve and Paula
    Indigo E35-2 #446
    Annapolis
  14. #14
    Principal Partner Kenneth K's Avatar
    Join Date
    Mar 2016
    Location
    Gig Harbor, Wa
    Posts
    480
    Blog Entries
    8
    Quote Originally Posted by garryh View Post
    Me too. I rely on seacocks (being closed), and not bilge pumps, to keep my boat floating.
    I presently don't have an automatic bilge pump system at all. What good would it do--the boat is in an isolated location, on a mooring ball, and without AC power. An automatic bilge pump would only guarantee that the boat sinks with dead batteries during one of the 3-4 day peiods I might go without checking on it.
    For me, closed seacocks are the best insurance.
    Ken
    '85 E32-3 "Mariah" #641
    Universal M-25
    "Saltwater is the cure; sweat, tears, or the sea......"
  15. #15
    Join Date
    Feb 2016
    Location
    lake michigan
    Posts
    35
    New temperature gauge on order and blower switch dried and cleaned. Casualties due to water half submerging the engine control panel during an offshore race.
    Yesterday there was shooting water up the starboard drain when healed over. Don’t like wet feet on a star filled night. There has to be a better way
    Randy Conner
    “Antares”
    1985 E35-3 #217
    Universal M25
    Waukegan, Il
Similar Threads
  1. Cockpit Drain Problem
    By Joed7 in forum Maintenance & Mechanical
    Last Post: 08-16-2018, 12:18 PM
  2. E-38 Cockpit Drain Question
    By Loren Beach in forum Maintenance & Mechanical
    Last Post: 01-25-2017, 10:12 PM
  3. 23' Erison Cockpit Drain
    By dan.utinske in forum Maintenance & Mechanical
    Last Post: 07-03-2014, 03:59 PM
  4. Bilge Drain & Cockpit Drain Question - Ericson 23'
    Last Post: 06-17-2014, 07:26 AM
  5. Cockpit Drain Lines
    By GMaurer in forum Maintenance & Mechanical
    Last Post: 03-02-2009, 11:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
